Help me not fry my eloctronics please
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jem454, Jun 18, 2009.
  1. jem454
    jem454 New Member
    I will be starting my sim very shortly, and know very little about electronics. :brows:
    My amc and hbridge are nearly finished, and I dont want to fry them. I am really confused about the grounding on the motors,and need some help.Could someone explain which wires I will use and how to isolate the ground.(this is the part I dont understand)
    [img]http://img3.imageshack.us/img3/2216/delcowiperdiagramcopy.jpg[/img]
  2. jem454
    jem454 New Member
    Heres a better pic showing the ground strap.
  3. RaceRay
    23,876Coins
    that should helps a lot:
    Here is a small pictuere tutorial how to isolate the ground:
    post7052.html#p7052
    Use a resistancemeter and measure if there is a connection between plus pole and casing of the motor.
    Anywhere there should be a video tutorial about isolating the ground..but i didn´t find it. Maybe youtube helps
    What kind of motor is that?
    best regards
    René
  4. jem454
    jem454 New Member
    Its a Delco wiper out of mid 80's cadillac.
