Help choosing an OSW motor
Discussion in 'New users start here - FAQ' started by Theodore Fataliev, Aug 22, 2020.
  1. Theodore Fataliev
    Theodore Fataliev New Member
    54Coins
    Hello everyone,
    Just recently stumbled upon the osw project and I am very happy to see more and more people step away from the cheap commercial shite Logitech is pushing to newcomers.
    So as I understand the Rolls Royce of motors is the Big Mige with a biss-c encoder.
    However shipping from China can sometimes be equivalent to the cost of the motor.
    So I found a morphon motor which has the same model naming scheme as the mige lineup : morphon 130ST M15025 on Amazon for 100 dollars .
    It does not have a biss c encoder (only 2500ppr). Otherwise it a 15nm motor with 30nm peak
    Here is the link
    I plan to use a simucube motherbaord with a ioni pro driver and psu
    Do you think this motor can be upgraded down the line to a biss c encoder ?
  2. Gadget999
    11,953Coins
    I suggest you use the AASD 15/30 driver
    Very commonly used in the sim world
  3. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,439Coins
    AC motor, 6DOF
    Hi Theodore. Welcome to the forum. I am working on a DD wheel at this time also. I have been researching things a bit and always looking for the best solution with the lowest cost... This motor/driver combination looks to be a good deal if you are in the US.
    www.amazon.com/gp/product/B07W4K64S6
    The Thanos driver board runs about $85 shipped (although backordered at this time) You can hand wire one for about $50 (DIY) and then you will be on your way to a working system..
    Good luck my friend
  4. Theodore Fataliev
    54Coins
    So here are my following questions
    Will the simucube motherboard provide a better experience? Ie better driver updates, firmware updates, etc
    Will I need to / be able to upgrade by encoder to a 4.2 m encoder later down the line ?
    How significant is the difference between a 2500ppr and a 4.2 m biss-c encoder
  5. Mike Melga
    Mike Melga Member
    IT
    Portugal
    661Coins
    Hi.
    Can you tell me where to buy those boards? Thanks.
    That boards replaces exactly what? The simucube + Ioni? Seems to good to be true :)
