  4. All new posts and threads should be written in English. Please do not create dual posts in other languages. If you are not a master of the English language you can use an external service to create a translation of your words, for instance, Google translate or DeepL.
    Due to low activity, we've also closed the french section.
help, Button box using the JC32 joystick controller?
Discussion in 'DIY peripherals' started by That Dude There, Nov 5, 2017.
  1. That Dude There
    That Dude There Member
    USA
    430Coins
    It's been a while since I've been asking questions. :p
    I'm wanting to build a button box with buttons, pull switches, and rotary encoders with push button feature. I want to use a JC32 joystick controller by Symprojects. In their diagram they show wiring a rotary encoder with 3 wires, similar to the DSD 32 button controller. The thing is the rotary switch I think I need that has a push button feature has 5 wires. Can anyone tell me if this switch will work?
    edit: link not allowed. Sorry but if you need to, you can search amazon for "DIKAVS 360 Degree Rotary Encoder Code Switch DIgital Potentiometer".
    Thank you!
    switch data sheet that works: https://www.sparkfun.com/datasheets/Components/TW-700198.pdf
    jc32: https://www.symprojects.com/categories-joystick-controllers/jc32-joystick-controller
  2. Ads Master
    Ads Master
  3. That Dude There
    USA
    430Coins
    It looks like only 3 wires are needed in this switch, even though there are 5 terminals. I'll confirm once all parts get here.
