Resolved hall sensor not working
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by bruce stephen, Oct 2, 2015.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
    154,580Coins
    +11,190 / 57 / -2
    Have you ensured the pot is centered, the motor moving away sounds like it is not.
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
  4. SeatTime
    You cannot swap the poles on a Hall sensor as you are actually powering a small circuit board inside the case.
    • Agree Agree x 4
  5. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    You need to swap the poles on your motor, Thats the way I've done it.
    • Agree Agree x 3
    • Useful Useful x 2
  6. Historiker
    Michigan USA
    9,212Coins
    What Tombo and Seattime said is absolutely correct. I use those pots as well.
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    Ty all. So simple yet i messed with it for an hour. I'll try after work.
    update: reversing poles on motor fixed it. also had to reverse motor in axis settings for simtools to compensate.
