Question Ground Connection / Aterramento
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Marcos73, May 18, 2020.
  1. Marcos73
    Marcos73 Member
    184Coins
    My structure has no contact with the ground, as it is supported on polymer bases.
    - My socket has three pins (phase, neutral and earth), but only the source is grounded, the structure is not.
    - My engines are not windshield wipers and have no ground wire.
    Do I need to ground the structure? (ground connection!?)
    Minha estrutura não tem contato com o solo, pois está apoiada em bases de polímero.
    -Minha tomada tem os três pinos (fase, neutro e terra), mas somente a fonte está aterrada, a estrutura não.
    -Meus motores não são de limpador de para-brisa e não possuem fio terra.
    Preciso aterrar a estrutura?
    (fio terra!?)
  2. Ads Master
    Ads Master
  3. EduardoMoreira
    EduardoMoreira New Member
    98Coins
    if the outlet does not have a ground wire, yes
    Se a sua tomada não tiver o fio terra sim.
  4. Marcos73
    Marcos73 Member
    184Coins
    My socket has three pins (phase, neutral and earth), but only the source is grounded, the structure is not. Do I need to ground the structure then?
    I've already burned two Arduino boards. rsrsrs
    Minha tomada tem os três pinos (fase, neutro e terra), mas somente a fonte está aterrada, a estrutura não. Preciso aterrar a estrutura então?
    Já queimei duas placas Arduino. rsrsrs
  5. Eliseu
    Eliseu New Member
    Portugal
    110Coins
    I don't know your electrical circuit, but normally the best sollution is connect all metal pats to the ground...
    Are you using a power supply? You can also connect the negative connection to ground...
    It´s like a car, the negative pole is connected to the chassi...
