"Globe" style (pitch, yaw, roll) G-force simulator?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by chalmers, Apr 24, 2009.
  1. chalmers
    chalmers New Member
    Hi, has anyone ever thought about a globe style simulator? Here's what I mean in terms of the basic mechanics:
    It would allow motors to be directly mounted on the roll and pitch arms, while the whole unit sat on a turntable for yaw. Power could be routed through the system and between motors using a circumferential interface through the pitch, yaw and roll interfaces.
    Does anyone think this would be possible? It's all a matter of how much torque each motor could exert. Here's a really horrible diagram:
  2. egoexpress
    And how do you want connect monitor and input devices?
    Regards
    Btw,
    gyrosim-t687.html
  3. chalmers
    chalmers New Member
    The monitor, computer and input devices would be inside the sphere/geodome. You would only need to route AC power through the system for the hardware. Everything else would be self-contained.
    Edit: Thanks for the link. The mechanics are exactly what I mean :)
  4. Fahim
    Fahim Member
    307Coins
    lol... that thing would drive you nuts :)
    You could have that dome style frex screen built inside. curve screen.
  5. tpba
    tpba Member
    IT
    Melbourne, Australia
    374Coins
    Have you seen the Sega R360 ?
  6. Alviomsim
    Alviomsim New Member
    Electronic Assembler
    USA
    344Coins
    Actually One simulator had This kind a Configuration And Works DESDEMONA create by 5 Holland Mechanical Engineer
    Desdemona: the next generation in movement simulation
    The multi-purpose Desdemona simulator recently installed at TNO will definitely push the limits of movement simulation. Desdemona is a movement simulator, disorientation trainer and advanced research lab, all in one. This simulator – unique to the world – can be used for both research and the simulation of complex situations that may occur during flight, driving or even sailing.here is the link and some photos
    regards to everyone
    http://www.youtube.com/watch?v=ZAlXuqKf ... re=related
  7. RaceRay
    23,875Coins
    Look like the guys were insprired by the movie contact :) If money is not an issue i prefer a small livingroom suitable 6DOF platform :lol:
