G-Loc motion sim conversion
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by cruzebabuze, Feb 22, 2016.
  1. cruzebabuze
    cruzebabuze Active Member
    135Coins
    hi everyone, I just got an old G-loc arcade that seems in perfect condition beside the screen and boards. I am going to convert it to a regular motion simulator. I saw 2 threads on this forum about it but they do not go really far in the build. Anyone has any idea of what motor I can replace with the original motor. Original motor are like 90v and I would like to use 12v so I can use the jrk I already have. So,if anyone has any ideas on motor conversion or arcade conversion please let me know, thank you
  2. cruzebabuze
    135Coins
    Ok so I took the beast apart and all boards, and monitor were dead, eaten by mice. It does not matter because hydraulics are in great shape and ran perfect. I cleaned it up and connected a stable power supply to motors and started to test diff Voltages. Start to move real slow at 12v, runs ok at 16v and run well at 24v) Jrk are able to take input all the way to 16v with a good fan. I found potentiometer and hook it up to jrk (I know jrk only 12v and beast motor need 24v). I hooked only one jrk so only one axis. I use the learn and did the pid and voila it tested properly in the game engine. Now tonight I will hook up the other jrk and set it up reverse to other in game engine. It still slow with 16v so I will have to:
    - change motors to 12v if I want to stay with jrk
    or
    - Switch to arduino and pololu 24v shield (but I do not have arduino sketch for it and my coding skills are not that great) Anyone has a sketch or can code it for me? (I am ready to give a little cash to coder for that job)
  3. cruzebabuze
    135Coins
    hum, I just did the connection for other jrk and everything is good. now I need to define axis 2 in game engine. Any suggestion?
    thank you
    150,602Coins
    +11,017 / 55 / -2
    Copy what you have in the Game Engine Interface1 Settings Tab into the Interface2 Tab and then change Axis1 to Axis2.
  5. cruzebabuze
    135Coins
    ok thank you easy enough. I am new to that, what can I get with that arcade setup? Roll and pitch? thank you
  6. cruzebabuze
    135Coins
    Hi there, I have one more question for you, where can I find the sketch to control g-loc motors unsing anrduino and pololu 24 motor shield, thank you in advance
    150,602Coins
    +11,017 / 55 / -2
    While a 2DOF has roll and pitch it can also be used to simulate sway, surge and heave.
    Which Pololu card are you using? You may want to check the comments here: http://www.xsimulator.net/community...rk-instead-of-jrk-12v12-this-is-a-24v12.3061/
    @michto35 runs a 24V pololu, so perhaps can comment on their use: http://www.xsimulator.net/community/threads/playseat-2-dof-24v-arduino-pololu-oculus-rift-dk2.6140/
  8. cruzebabuze
    135Coins
    I was using pollution 12v and pushed them to 16v, with good fans, and it is close but not enough power, I need to use 24v as intended for motors. So I wanted to switch to an arduino setup with a pololu motor shield rated at 24v? What do you think and what sketch can I use to make it work? Thank you
    150,602Coins
    +11,017 / 55 / -2
  10. cruzebabuze
    135Coins
  11. cruzebabuze
    135Coins
    Yes that is what I though about the pololu 24v, I think I am going to follow your advice and get a sabertooth, what is the best place for it? Thank you
  12. noorbeast
    150,602Coins
    +11,017 / 55 / -2
    You would need to Google suppliers and compare prices + shipping for Sabertooth.
  13. cruzebabuze
    135Coins
    How easy is it to setup the sabertooth? Thanx
  14. bruce stephen
    general contractor
    michigan
    9,114Coins
  15. eaorobbie
    20,463Coins
    Agree @bruce stephen my only choice for Ard(ady) motion it does it better than most.
  16. cruzebabuze
    135Coins
  17. bruce stephen
    general contractor
    michigan
    9,114Coins
  18. cruzebabuze
    135Coins
  19. cruzebabuze
    135Coins
  20. bruce stephen
    general contractor
    michigan
    9,114Coins
    25w 2amp so i would say no, this is weak....................
