Question Full range trough Axis plugin
Discussion in 'SimTools Pro & Entertainment Version' started by Trigen, Oct 19, 2019.
  1. Trigen
    Trigen Active Member
    2,890Coins
    Hello
    Im trying to have my hall sensors use full range so i can use it with one magnet. I have it somewhat working but id like someone to look at the code and perhaps say if its the correct way or not.
    Ive put the Sway (for simplicity i should probably put it on another force) so it starts from -1 and adds any value to that. I then multiply that 2 times so it will use the whole range. I still dont quite understand why the axis is flipped when you do Axis1_Value1_Out * -1 but putting 1 instead of -1 works and since this is on sway and one axis needs to go the other way i use -1 and 1. Feel free to give an explanation why it gets flipped
    Doing this on 2 DOF's seems to work for all as its instantly put to -1
    Also what happens if i wish to use -0.8 instead of -1 for full range so i can have some negative heave and or surge?
    Code:
                    Select Case ._Axis1DOF1
                        Case "-"
                            Axis1_Value1_Out = 0
                        Case "Sway"
                            'Get percent used for DOF
                            Axis1_Value1_Out = _Sway_Input * (._Axis1PER1 * 0.02)
                            Axis1_Value1_Out = 1 + Axis1_Value1_Out
                            'Flip if necessary
                            If ._Axis1DIR1 = True Then
                                Axis1_Value1_Out = Axis1_Value1_Out * -1
                            End If
                            ' If Axis1_Value1_Out < 0 Then
                            'Axis1_Value1_Out = Axis1_Value1_Out * 0
                            ' End If
                    End Select
    Axis 2
    Code:
                    'DOF1
                        Case "-"
                            Axis2_Value1_Out = 0
                        Case "Sway"
                            Axis2_Value1_Out = _Sway_Input * (._Axis1PER1 * 0.02)
                            Axis2_Value1_Out = -1 + Axis2_Value1_Out
                            'Flip if necessary
                            If ._Axis1DIR1 = False Then
                                Axis2_Value1_Out = Axis2_Value1_Out * -1
                            End If
                            ' If Axis2_Value1_Out < 0 Then
                            ' Axis2_Value1_Out = Axis2_Value1_Out * 0
                            'End If
                    End Select
    Thank you
  2. yobuddy
    51,510Coins
    Axis1_Value1_Out * -1 just flips the sign of the output value with the little Dir checkbox.
    If value is 5 then its -5.
    If value is -3 then its 3.
    that's all really.
    Take care,
