Frex vs. DIY - cost is near identical
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by dre99gsx, Nov 15, 2008.
  1. dre99gsx
    dre99gsx New Member
    I did a quick sum of all my parts to create a FREX-like simulator:
    $750 in brackets/screws/extruded tubing
    $900 for 2xSCN5 units
    $70 for 2xBall Ends for the SCN5s
    $100 for 6 Ball ends and rods for stabilization
    I still have to account for the time to cut and mount everything. A FREX shipped to the US goes for $2400 or so. I'm still missing a few things (power supplies, cabling). The guys who create the SimConMotion package really do drive a good bargain. Although a DIY is great for a bargain, I just did not want some hack job simulator that would sit in my living room. It needs to at least look good, be compact, and last.
    I'll update this regularly as I progress. Hopeing to jump on the bandwagon with X-sim2 and SCN5s.
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    I have about $1300 in my design including everything that you mentioned, plus all of the adapters, cables, power supplies and vibration / shock mounts. I believe that it will outperform the original design that you you are taking about in every category except for ease of assembly. I will be posting pictures of it once it is complete and I have validated the concept.
    For now, shop around a little. Every proce that you quoted is way to high except for the actuators.
  3. egoexpress
    You could save alot by using a welded steel frame, instead of T-slotted aluminium extrusions with brackets.
    Regards
    Christian
  4. dre99gsx
    dre99gsx New Member
    My goal is to make a portable unit that I can dismantle and travel with, yet be sturdy when assembled (hopefully with very few steps). I found the cheapest prices on Tslots 1.5 square that I could. There was just quite a bit of hardware involved. Most of the stuff is coming from 80/20Inc.
  5. nordisch
    nordisch Member
    Germany, Hamburg/Lübeck
    61Coins
    I think you can`t compare Frex with DIY X-Sim ...
    DIY is our open source Product 8) for many applications
    ... FREX is shiges limited source Product :yes: for a handfull racing games.
    We are not end-consumers.
  6. Mr Burns
    Mr Burns New Member
    Frex support is horrible, update come once in a blue moon for any new patch, a lot of stuff just doesn't work or will ever work. Of course you could hook it up to the x-sim software, but you will not get any help from frex.
