Force Dynamics/Motion-sim.cz
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Fahim, Nov 19, 2016.
  1. Fahim
    Fahim Member
    553Coins
    Can I ask why would motion-sim.cz go from 3 actuators to 4 actuator in the last few years?
    Their first design was based like the force dynamics simulator which I believe use three actuators.
    Two at the sides and one right behind the driver seat.
    The only reason I can think of is if the single actuator behind could not take the force or the motor overheats so add a second one to keep things cooler?
    As I can't understand the benefit in terms of feel of have two actuators joined together right behind the driver seat.
  2. yobuddy
    51,690Coins
    My guess is it does Yaw with the back to actuators?
  3. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,341Coins
    2DOF, Arduino, 4DOF
    They got traction loss and also release some load from the other 3 actuators. My next sim will be based on that.
  4. Fahim
    Fahim Member
    553Coins
    So 4dof the back actuators are yaw( spinning or losing back end)
    So what about the pitch (back/forward). The back actuators share yaw and pitch together?
    For example we 2DOF users share roll and pitch with the same actuators?
  5. yobuddy
    51,690Coins
    I believe the front actuators do, Pitch, Roll and Heave.
    And the back actuators do Pitch, Yaw and Heave.
  6. SeatTime
    I will be interested in what you guys come up with - I did look at doing a design like this but ended up still going with a stewart platform - as this design has allot of side loads which my actuators could not handle without some serious redesign and 6DOF is of course better than 5DOF :).
