Question Flyinside with X Plane
Discussion in 'SimTools Pro & Entertainment Version' started by SEHATanguy, Nov 1, 2017.
  1. SEHATanguy
    SEHATanguy Member
    Belgium
    96Coins
    good morning,
    I tried to run my rig with my VR headset, but to fly in VR with X plane 11 we must have another software that is Flyinside (this will run X Plane in VR mode)
    The problem is that if I run Flyinside, Simtools doesn’t recognize (however I think) that X plane is launched, so my rig is not moving when I’m in game
    Is it something that I can do to tell to Simtools than he must be ready when I use Flysinde?
    Regards
  2. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
  3. SixDegreesOfFlight
    SixDegreesOfFlight Well-Known Member
    Secondary Teacher: Systems Engineering & Computing
    Melbourne, Australia
    2,224Coins
    @SEHATanguy
    There is an undocumented issue with running Flyinside.
    I have found that I need to run XP11 without Flyinside first, then use SimTools to patch the game. Then start XP11 using the Flyinside icon and then setup the Data Output page from there. The undocumented part is that if you set up the Data Output without Flyinside it saves the configuration differently than if you save the configuration while running Flyinside.
    It will fix your problem :)
    • Informative Informative x 3
