fightin with SCN5 actuators *need help*
Discussion in 'Motor actuators and drivers' started by logic1208, Jul 12, 2014.
  1. logic1208
    logic1208 its more safe for me, to drive sims ;-) SimAxe Beta Tester Gold Contributor
    switzerland
    510Coins
    SCN5
    hi
    im building a seatmover sim right now. progress see here ( german ):
    -> http://www.xsimulator.net/community/threads/seatmover-snc-sim-work-in-progress-german.5626/
    but i have a problem to bring the scn5 to work.
    i use following hardware:
    2x scn5
    2x usb to rs485 ( the same as seppel use )
    1x meanwell 24 v powersupply
    when i connect the software (simtools or the scn software), the usb connector begins to flash.
    with the original software i can up and download the original scn eprom files.
    so i think the connection is ok?!
    but i cant bring the snc5 to move.
    in the manual i have seen, theres a emergency stop. could it be, that the emergency stop is as standard
    activated and i must solder an ressistor in?
    thanks for any help,
    andré
  2. eaorobbie
    20,465Coins
  3. logic1208
    switzerland
    510Coins
    SCN5
    @eaorobbie, thanks !!!
    i read almost the hole Forum up and down, but did not find this thread...
    must buy first a resistor and Switch, then try it on early next week....
  4. eaorobbie
    20,465Coins
    No worries @logic1208 that's what we are here to do , help and guide where needed.
  5. nclabs
    196Coins
