Ferrari_man's simulator project
Discussion in 'DIY Motion Simulator Projects' started by Ferrari_Man, Jul 25, 2007.
  1. Ferrari_Man
    Ferrari_Man Member Gold Contributor
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hello out there.
    I am trying to build a race simulator like the SimForceGT (or flex).
    I almost finish with the frame and mounting the seat.
    I want to use pneumatik valves and cylinders and a Velleman VM110 because I already have them.
    I also want to use the setting from Frex, because then no pots just springs. But not sure what more I need.
    I have:
    2 5/3 Festo Valves
    2 Cylinder
    1 Velleman VM110 (Conrad K8055D)
    1 Logitech Momo Race
    and off cause the frame, seat and so on.
    And last is the a guide about where to start when I am ready, or do you just try something. (I have been trying Force sender with my logitech for a sneak peak)
    Ferrari_Man ...DK
    Some pics:
    [​IMG][​IMG]
    [​IMG][​IMG]
  2. egoexpress
    Hi
    Wellcome!
    You have the frame and the pneumatic equipment. Perfect! The rest is just trying ;)
    Are your valves center open or closed?
    Tell me the dimensios of your cylinders, and how many connections do they have.
    After your setup is ready, you'll have to change the valve matrix a little. The Y -axis has to combine both cylinders.
    You'll get help with it when time has come.
    You could show us some pics of your setup ;)
    regards
  3. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey..
    Sounds super. I will take some pictures soon. (Just have a little holiday trip first)
    Are your valves center open or closed .... they are open ( I have one closed for the seatbelt but I think thats going to be the last part of it)
    Tell me the dimensios of your cylinders, and how many connections does they have.... they are 200mm long and 10mm thick. They are double working with adjustable brakes(drosselventil)
    You'll get help with it when time has come.... looking forward to it.
    Ferrari_Man
  4. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    One more thing. How must difference is where between using slider-pots and just using a springs.. and how much truble are they to use with the velleman vm110
    Ferrari_man
  5. egoexpress
    I think the spring setup is less good, because it doesnt allow positioning. Only center position will be forced by the springs.
    As you bought center open valves, you dont have another option
    But it is worth trying anyway ;)
    ego
  6. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Its no problems with the valves, because I got them for free. (at work)
    I think I will try to get 2 closed also... and the slider pots..
    Do you have a link to the sliderpots that would need (it 10k right?)
    Then I can start with the springs and when I get the parts I can try then instead.
    Thanks for your help so far...
    Ferrari_man
  7. egoexpress
    If you'll use an pot measurement system and middle closed valves you wont need springs.
    Besides that. I dont know how you'll attach them. That will be the tricky part. Do you have some ideas already? You could try to use some hall-sensors.
    We have our pots from this supplier.
    I and most of us use 20K pots. 50K are used in the original RnR boards. Perhaps 10K work as well.
  8. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    How long are the slider pots you use.. The longest I could find where 100MM and 50K.... but how that work with 200MM cylinder...
    What do you use?
    How much can your cylinders move... is 100mm enough ?
  9. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey
    Do you have any pictures of how you mouted it... I dont understand how its done.
    Ferrari_man
  10. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    If anyone has any ideas or espcially pictures for mounting sliderpot on at cylinder when they are different sizes. (I dont understand the control rod thing... whats that?)
    Ferrari
  11. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    okay now I understand better what you mean. But where would you recommed to mount it on the SimForceGT chair.(or frex)
    Ferrari
  12. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    okay but I only need 2 slider pots, right?
    It is because the places where I have tryed to mount the sliders they have been some problems... when I make one of the cylinders move both og the sliders move because the whole chair moves.
    the slider for the cylinder where is moving is ok, but the another one shoud stand still right?
  13. egoexpress
    Hmm, Illi attached some pots to his cylinders, but they are shorter as yours.
    I think 200mm are too long anyway...
    http://www.x-simulator.de/forum/uploade ... C00436.JPG
    http://www.x-simulator.de/forum/erstes- ... -t258.html
    If you find a supplier who sells cheap and durable pots (not plastic) as long as those, let us know ;)
    Yes
    But perhaps you dont have to attach them directly to the cylinders. Try to attach them to your pivot point under your seat.
  14. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
  15. egoexpress
  16. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    ... cool... Now I know that to do... :D
    I will gets some 100mm and 60mm then I see what fits...
    how smoth can the pneumatik cylinder move compaired to electric cylinder
  17. egoexpress
    too much smooth to simulate curbs^^
  18. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey
    My setup is almost finish. The frame is almost done just need at chair and the wiring and a new kompressor. (but the chair will first arrive in 10 days........)
    Is there any files or helps to setup the matrix for a simforcegt setup.. just to get started. So I could play with it until the chair arrives.
    Ferrari
  19. egoexpress
    You could motivate us a little bit with some pics ;)
    BTW, how is your setup gonna be like? 2 or 4 valves, middle closed or open? Every modification of the setup needs another config in the matrix.
  20. Ferrari_Man
    Copenhagen
    - 5Coins
    SCN5, SimforceGT
    Hey
    I have taken some fotos and here they are.
    It is going to be 2 valves with middle open. (because I dont have the pots yet only springs)
    uploader/pool/IMAGE_071[1].JPG
