Fact or Fiction
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by dartzman, Nov 11, 2009.
  1. dartzman
    dartzman New Member
    Would I be right in saying that it is better to have the actuator closest to the pivot, this will elliminate the need for an actuator with a long travel distance and also weight lifting capabilities = Cheaper Actuator?
  2. CXCSimulations
    CXCSimulations Member
    - 9Coins
    No, the closer you get to the pivot, the more thrust force you will need.
    Think of it like bicycle gearing; the taller the gear, the faster the bike will go but the more force you will need to pedal.
    It is a fine balance needed to optimize actuator choice and placement. I recommend testing this thoroughly to optimize your setup.
    Good luck!
  3. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    I fully agree. Use the test plugin to optimize your actuator placement. You will find that have them on a steeper angle closer to the pivot will be less efficient in most cases.
    ....Mike
