Elite Dangerous Horizons Plugin (Non VR Version) [Deleted]
Discussion in 'SimTools Plugins' started by value1, Dec 22, 2014.
Thread Status:
Not open for further replies.
  1. faro06
    faro06 New Member
    - 139Coins
    Thanks. I check every day if we have a update :)
  2. SilentChill
    20,604Coins
  3. zigzag49
    zigzag49 Active Member
    726Coins
  4. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
    hi @SilentChill
    i tried the new plugin, and i guess theres a problem with the ROLL function.
    I'm quite sure that this works one time, but after restart the game i've the following issue.
    ROLL seems to stuck in one position, see video .
    could this be a plugin issue ? Or is that a setup issue on my side ? If I test all DOFs manually, then everything is fine and the ROLL works properly .
  5. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Does anyone have this plugin working with the Steam version of Horizons?
    The plugin goes blue, however I only get Pitch as a moving value in the Tuning Centre.
    I have patched the game to: \Program Files (x86)\Steam\SteamApps\common\Elite Dangerous\Products\elite-dangerous-64
    Any ideas? Thank you :)
  6. SilentChill
    20,604Coins
  7. kermitkong
    1,240Coins
  8. mohammad
    mohammad Member
    iran
    159Coins
    hi @SilentChill
    tank you for plugin
    I test a plugin two problem
    1.roll no move
    2.game Data is constantly on and off the field
  9. kermitkong
    1,240Coins
    hi @mohammad ,
    are you sure that you tested the updated version from @SilentChill ?
    The first version had this problem, yes, but the updated version runs quite well on my side.
    please check, maybe you forgot to reptach the game with the latest version.
  10. mohammad
    mohammad Member
    iran
    159Coins
    hi @value1
    can you place elite dangerous horizons source ?
    tank you
  11. mohammad
    mohammad Member
    iran
    159Coins
    hi @kermitkong
    I download new update and install in simtools but never change in game.:(
  12. kermitkong
    1,240Coins
    do you have the Elite on Steam or on the frontier ? Maybe there's some differneces.
    I will double check the current plugin by tonight, to see whether this works as expected on my 6DOF system.
  13. SilentChill
    20,604Coins
    I need to thin out the pointers more, sorry just have not got a massive amount of time to keep scanning resetting scanning resetting start game stop game start game stop game.
    @mohammad if you want to find some stable pointers I will check them at my end also that would help. Remember you have to find pointers that don't bounce around when in stations and also the roll address is separate to the Sway/Heave/Surge/Yaw/Pitch location.
    Another thing when you find the pointers you have to be sure they all don't go crazy when you turn flight assist off and then there is jumping into cruise that can make them go all crazy too !!
    Sharing the source is no good unless you can find all the stable pointers, its not the easiest thing to do and very time consuming.
    I will try more tonight when I get home I may have an hour or 2
  14. SilentChill
    20,604Coins
  15. value1
    14,280Coins
    Hi @mohammad
    As mentioned by @SilentChill the plugin code is not the difficult part (haha, at least once we solved the reading-64bit-memory-from-32bit-program-part :) )
    You can really help and contribute by finding the good pointers in Cheat Engine!
    See post here
  16. zigzag49
    726Coins
    thank you for the plugin , the latest version of the roll saccade home.
  17. SilentChill
    20,604Coins
    Eh ???
  18. zigzag49
    726Coins
    the roll saccade after unpatch then re-patch the simulator works well but without roll. on border there are two launch mode x64 and x32, I 'll try 32.
  19. zigzag49
    726Coins
  20. SilentChill
    20,604Coins
    I have no idea what saccade means ??
    The plugin works only for 64bit horizons
Thread Status:
