electric screw jack
Discussion in 'Motor actuators and drivers' started by Gadget999, Nov 21, 2017.
  1. Gadget999
    11,941Coins
    150,602Coins
    +11,017 / 55 / -2
  3. Gadget999
    11,941Coins
    ok - they are using the motors with a lever arm
    i was thinking more along the lines of removing the screws and attaching them directly to the motors for the basis of a linear actuator
  4. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    If I understand correctly, it is too slow to be used that way. also the efficiency will be low.
    150,602Coins
    +11,017 / 55 / -2
  6. MarkusB
    4,213Coins
    So you think of disassembling the scissor jack, take the screw for making a linear actuator, and throw away the scissor mechanics? (Just to make sure that I/we understand you correctly.)
  7. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Yes, The screw runs at only 70rpm over a really basic "nut".
  8. Gadget999
    11,941Coins
  9. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Sure, for the slowest actuator in the world...
  10. Gadget999
    11,941Coins
    i suspect the motor may not be suitable - it may need a gearbox or more power
