electric drills as actuator motors ?
Discussion in 'Motor actuators and drivers' started by Gadget999, Dec 5, 2018.
  1. Gadget999
    12,331Coins
    has anyone used an electric drill as an actuator motor ?
    the more i look at them the more they seem to make sense
    they are DC and can be controlled with a h bridge
    they have adjustable gear box ratios
    they are designed to work in tough environments
    they are cheap
    they are readily available
    could be modified to add some cooling fans etc
    is there a video of one in action on a sim ?
  2. Alexandre Piccini
    Alexandre Piccini New Member
    190Coins
    DC motor, AC motor, Arduino
    Bumping the thread. I've had the exact same idea.
  3. Meng
    Meng New Member
    114Coins
    速度控制、位移控制比较麻烦,另外加编码器或变频器吗?
    Google translate:
    Speed control, displacement control is more troublesome, plus an encoder or inverter?
  4. Alexandre Piccini
    190Coins
    Thanks for the reply Meng. Getting displacement control from something you have speed control is not as hard as it may seem. I can help you guys with this, since my work is related to control systems. Specially if you have an encoder working together, this gets pretty easy.
    Did you ever work with electric drill motors?
