Dual PC Question
Discussion in 'SimTools DIY Version' started by CoachKalk, Sep 16, 2014.
  1. CoachKalk
    CoachKalk Member
    970Coins
    While I am waiting for a new JRK, I figured I would try to set up a dual PC for controlling purposes.
    My first question is do I need to have my JRK's plugged in to test? Or will SimTools still send Game Data - Input even though I have no controllers/motors hooked up to do anything.
    I followed the instructions in the FAQ section and everything followed along fine. I successfully changed the IP address in GameManager so it was "Connected" just like the instructions showed. On my second PC I opened GameEngine and Tuning Center. I am not getting any Game Data Input but that may be caused by me trying to test with "stuff" hooked up.
    My second question is regarding LFS. I know the plugin is/was included in the SimTools download, but how do I get the zipped plugin by itself for my PC2? Or do both PC's have to have SimTools and the games themselves?
    Thanks,
    Steve
  2. eaorobbie
    20,400Coins
    Need to install SimTools on both PCs , LFS plugin will install too.
  3. CoachKalk
    CoachKalk Member
    970Coins
    @eaorobbie - I have SimTools on both but I was trying No Limits not LFS. I will try LFS next to see if I can receive data input on my PC2. Do you know if I can test the PC set ups without the JRK's plugged in?
  4. eaorobbie
    20,400Coins
    No needs an interface setup. But actually doesn't need to be plugged in SimTools will let out a couple of beeps to warn you an interface error has occurred.
  5. value1
    14,509Coins
    @CoachKalk: you don't need to have the JRK's plugged in but you need to have the interfaces defined and axis assigned! Otherwise there will be no data in Tuning Window!
