DIY Tactile Transducer
Discussion in 'DIY peripherals' started by Edwin Collingridge, Nov 16, 2014.
  1. Edwin Collingridge
    Edwin Collingridge eSEA One
    717Coins
    This is my first of several projects to making a DIY simulator. I was given a Creative Labs Inspire 2.1 2400 speaker set that has a 4Ω 20W BASS speaker. Fair enough this is only a fraction the power of the commercial ButtKicker 90W transducer but without having to buy anything and having an amplifier that matches the speaker there is little to loose and experience to gain. [​IMG]
    And here is the finished transducer
    But now comes the tricky part to get XSimulator Simtools to take the data from Assetto Corsa and output it to my DIY Tactile Transducer. I have looked on the forums but struggling to find anything my brain can understand in simple terms
  2. bsft
    I know bass shaker is in development, but thats more for sound.
    So if you are going to set it up, that will do the job.
    Dunno about running it with data.
  3. Edwin Collingridge
    717Coins
    I found this "Tactile Transducer Setup Guide By Jeremy Paterson" that linked to this http://www.xsimulator.net/ site and that's one of the reasons why I joined here. maybe I got it all wrong thinking X-SIM and this site is one and the same!
  4. Edwin Collingridge
    717Coins
    I have the transducer working wonderfully with it plugged into its original amplifier which is plugged into the sound card (green L/R Front Jack) via a split-er the other output goes to my 4+1 sound system (the 4+1 is receiving the other signal from the black rear Speaker Jack) I also have a stand alone central self powered speaker receiving its signal from the sound card's Central Orange Jack.
    But unfortunately I can not get the Bass transducer to work if I plug in my USB surround headset :(
  5. RacingMat
    21,087Coins
    yep, x-sim can drive buttkickers but the effects are not what should be expected (higher frequencies should not be the strongest)
    so you have to wait: Simtools buttkicker's support is under development.
  6. Edwin Collingridge
    717Coins
    Well for now just sound driven transducer it is then. When there is no conflict with the family and sound is not an issue then I use the transducer with the surround system and then for quieter demands from the family, I just have to use my headset in the standard stereo 3.5mm jack mode as I can not use the USB surround mode with the transducer driven by the system sound card. I guess the next step is to use software - Virtual Audio Cable that allows a program to send sound data to more than one sound device but this could then take the cost of the device from €00.00 to €20.00-30.30.
  7. bsft
    Bass shakers here in Australia can be expensive, like over $100 easy, so even with your extra costing of 20-30 euros, its still a cheaper option.
    well done. I must go dig out a speaker somewhere, I think I have a 6"sub not doing anything.
  8. Edwin Collingridge
    717Coins
    This is a no brainer for most people, even the DIY challenged!
    • Some friend or family has an old speaker set that is just gathering dust. There is also ebay!
    • It is an easy project to do.
    • It is a quick project.
    • The results are bone shaking cool, even on the sound driven option.
    • There are lots of online info on this subject;
    The only challenge is if you want to use telemetry to dive the shaker!
  9. RacingMat
    21,087Coins
  10. Edwin Collingridge
    717Coins
  11. RacingMat
    21,087Coins
    I confused the video with a picture : good job! :D
    Have you ever experienced Buttkicker? so you could tell us how it is in comparison
  12. Edwin Collingridge
    717Coins
    No so I can not compare. One thing I can say it sure is better than nothing. :thumbs
    At the moment it is just running of sound and not through the Xsimulator software
  13. Bodax
    Bodax Member
    Belgique
    583Coins
  14. Bodax
    Bodax Member
    Belgique
    583Coins
    it is a can expensive, but easy and effective
  15. Quertreiber
    Quertreiber New Member
    Eppingen-Germany
    361Coins
    Simvibe is completely different animal than "sound". I bought it 3 month ago and i really adds immersion. Especially if one is using chasis mode with 1 transducer @ every corner. A nice axample:
    right frontwheel hits a curb, then the right front transducer starts to shake. Then right rearwheel hits it too, and both right transducer are shaking.
  16. RacingMat
    21,087Coins
    sorry, it's not easy at all: the software is complicated, many options, many control windows... I gave up
  17. noorbeast
    154,292Coins
    +11,178 / 57 / -2
    I am hoping @yobuddy is the solution, once he gets to implementing transducer support for SimTools ;)
  18. Quertreiber
    Eppingen-Germany
    361Coins
    So true. Most of the time I use only 3-4 effects. And it is way to expensive in my eyes. 1/3-1/2 of the price would be ok. Especially if you own other Simexperience products.
  19. RacingMat
    21,087Coins
    Yes, I bought 4 outputs amplifier and dayton puck in order to be able to beta-test:)
  20. Linkup
    Linkup Member
    Graphic Designer
    Sweden
    855Coins
    Do you have a picture of how you mounted the setup to the chair?
    I'm also wondering how long the bolt you're using is?
