DIY motion sim project. Please help me out!!!!
Discussion in 'New users start here - FAQ' started by elchef, Apr 21, 2009.
  1. elchef
    elchef New Member
    - 152Coins
    Hi
    My name is Christian and i'm from Argentina.
    My idea is to build a motion simulator.
    First i think i'll start with the interface does this one work?:
    Serial 8-channel relay board
    Name: Conrad Relay board
    Connection: Serial COM port
    optional USB (virtual COM)
    Operating voltage: 12-24V= , max. 300mA
    Channels: 8 Outputs,
    Licht24 PRO supports 3 cards.
    (use 3 cards for 24 channels)
    Relay contact: respectively 1xNO/NC, 230V/5A, without separate function and security checking it is max. 24V/4A for the complete application permitted!
    Indicator: every channel has a signal LED
    Size: 160 x 100 mm
    Art: Ready equipment
    Manufacturer:
    Supplier: Conrad Electronic (direct link)
    Article-No: 197720
    With a Pneumatic system: Cylinder 50mm, 300mmlong and 4 bar. Is it possible to hook it up with this conrad card instead of the one you used? Thank you verry much.
  2. RaceRay
    23,891Coins
