Question DIY FFB Encoder Help
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by GeoHan, Jul 2, 2021.
  1. GeoHan
    GeoHan New Member
    83Coins
    Hi All
    Been working on a DIY FFV Wheel with an Arduino and a Omron E6B2 1000ppr Encoder (Chinease Import).
    But I have been struggling to get a signal out of the endoder, I have verified the arduino and the software works using a cheap ~20 ppr encoder (the ones with the click button).
    I have tried with and without resistors (1k & 4.7K), with the Omron.
    I have read that I may need a higher voltage than the ardiono can provide, is this a comman issue?
    Does anyone have any ideas on what I should try next?
  2. Gadget999
    12,319Coins
    Are you feeding it 5v or 3.3v ?
  3. GeoHan
    GeoHan New Member
    83Coins
    I am using the 5v pin on the arduino
  4. Gadget999
    12,319Coins
    Try it with 9v to see if it works
    Are you using a pullup / pulldown resistor ?
  5. GeoHan
    GeoHan New Member
    83Coins
    Yes, I have tried with a 1k & 4.7k resistors.
    What would the wiring look like if i use an external psu rather than the 5v on the ardiono?
  6. Gadget999
    12,319Coins
    Use a different power supply and share the grounds
