DIY 2DOF Sim Cockpit using Simxperience software
Discussion in 'DIY Motion Simulator Projects' started by Ben Selph, Mar 12, 2015.
  1. Ben Selph
    Ben Selph New Member
    635Coins
    Hey All!
    I've been building my own cockpit for the last few months and have almost completed it. Now that the Accuforce wheel from SimXperience has come out with stellar reviews, I'm trying to decide how to go about building the 2DOF motion part since I'll be purchasing that wheel. I would like to use the SimXperience software since it uses the Accuforce wheel and Simvibe that I already use for my bass shakers as well. Is it possible to build my own motion sim and use their software to control everything together?
    Thanks!
    Ben
    • Old Old x 1
  2. Luc1gnol0
    Luc1gnol0 New Member
    Itala, Italy
    246Coins
    i follow this discussion, i have this problem
  3. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    If you want to use their software you need to use their hardware controller. You should post this in their forum.
    SimTools is a better solution compared to SimTools. I use both myself but only becauase I have simVibe and there is no issue using both.
  4. Ben Selph
    635Coins
    I'm assuming you meant SimTools is better than SimCommander (SimXperience software)? So there shouldn't be any issues with using Simtools for the motion rig and SimCommander for Simvibe and Accuforce wheel? I was worried they would conflict...Thanks!
  5. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Correct Sir. SimTools has a better response rate and is less buggy, more games, more updates, better community and others.
    Simtools and SimCommander dont conflict for almost 100% of all simulations. I think I heard that GRID might have an issue but not certain on the sim.
  6. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,262Coins
    All codemasters games have an issue that causes Simtools not to work with SimCommander or any other SLI/telemetry based program. The SimTools guys are working on a new plugin which will fix Codemasters games.
    @shannonb1 just out of interest, what was the last version of Sim Commander that you used?
  7. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    333Coins
    I'm building a 2DOF which and i will be using with Simcommander and Simtools.
    I want to use Simcommander for:
    -The accuforce
    -Simvibe
    -SX4000 motion kit
    -GS4
    I will be using Simtools for games that are not supported in simcommander or if i find that simtools is actually better than simcommander in certain games.
  8. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    I'm currently using four
  9. HoiHman
    Mechanic
    The Netherlands
    333Coins
    I have 5 buttkickers on the seat and 3 at the pedals.
  10. Radek vols
    Radek vols Member
    Czech Republic
    194Coins
    2DOF, DC motor
    5 buttkickerson seat? I thought one is enough :D
  11. Avenga76
    Network Engineer
    3,262Coins
    I have 8 transducers in total on my rig (5x Buttkicker Mini LFE, 2x Aura, 1x Buttkicker advance)
  12. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    I mean sim commander 4..... I have 12 transducers
  13. SeatTime
    Anyone with more than 12?:) I only use one on the seat - they are expensive in OZ.
  14. Radek vols
    Radek vols Member
    Czech Republic
    194Coins
    2DOF, DC motor
    Do you please have any photo or video?:) would like to see what it looks like :)
  15. Ben Selph
    635Coins
    What amp are you using to drive those transducers? I heard the Emotiva 500 was good but they apparently aren't making those anymore. Any suggestions for a multi-channel amp that's under 500 US?
  16. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    I ve seen a lot of cheap class D amps on eBay.
    Would it be a good idea to use these powered by 12v server PSU(s) and create an array of multichannel output for shakers?
  17. Nick Moxley
    17,057Coins
    I have 2 mini Lfe's in Gamer 2 Cages mounted to my seat, If i turn up my Dayton above 50% my eyeballs shake soo much and i cant see properly. Fortunately there's a Very unique feature about the Gamer2 frames which leads me to believe i would need 6+ standard mini LFE's to even come close to the same amount of shake, 1 gamer 2 VS 2 Standard Mini LFE's and the Gamer 2 was 3X as much vibrations.
    IMO the Mini lfe's are duds.
  18. Ben Selph
    635Coins
    I'm not sure what you mean by Gamer 2 'cages'? I've seen the Gamer2's but they seem to be hard to find these days. Are they even making those anymore?
  19. Nick Moxley
    17,057Coins
    Yes they still make gamer 2's and the "cages" meaning the mounting style the gamer 2 uses with the clamp and flexing arm the shaker is attached to.
    mini LFE's in Gamer 2 mounts are not something you would normally come across, it was a 1 off deal i did with Guitammer
