DiRT Rally Plugin [Deleted]
Discussion in 'SimTools Plugins' started by llluis, Jan 24, 2018.
Thread Status:
Not open for further replies.
  1. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    @zevsss
    I see you are a new member (welcome) and the question is simple:
    have you tried other plugins/games?
    Your motion platform regolary run with other games? :!
  2. zevsss
    zevsss New Member
    Russia, Alikovo
    82Coins
    the problem was solved. was incorrectly set to the folder of the patch
  3. cover4x4
    cover4x4 I love simracing
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    I still have not had time to try it, but as has happened to me in Dirt Rally 2, when using SimHub, it seems that I corrupted the movement, and as some users commented, it was a problem to rename the ports. In Dirt Rally 2 has been doing that and solve the problem, I hope that in this when I have a while I can do it and confirm it, but it looks like the same problem for something similar happens that you know ...
    A greeting.
    Todavía no he tenido tiempo a probarlo, pero tal y como me ha pasado en Dirt Rally 2, al utilizar SimHub, parece que me corrompía el movimiento, y tal y como comentaban algunos usuarios era un problema con renombrar los puertos. En Dirt Rally 2 ha sido hacer eso y solucionarse el problema, espero que en este cuando tenga un rato lo pueda hacer y confirmarlo, pero tiene pinta de ser el mismo problema para el que le pase algo parecido que lo sepa...
    Un saludo.
  4. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Yes, today I have been able to prove it and the movement is already working correctly with SimHub, it is a joy and it is that until now I played without movement, but now with a brutal movement the feeling of the rallies. I repeat, as I say it was renaming the ports, since with SimHub Simtools was incompatible.
    A greeting.
    Pues sí, hoy he podido probarlo y el movimiento ya funciona correctamente junto con SimHub, vaya gozada y es que hasta ahora jugaba sin movimiento, pero ahora con movimiento brutal la sensación de los rallys. Repito, como digo era renombrar los puertos, ya que con SimHub era incompatible Simtools.
    Un saludo.
  5. llluis
    Quebec
    1,631Coins
    This resource has been removed and is no longer available for download.
Thread Status:
