Resolved Dirt Rally alternative plugin (filtered)
Discussion in 'SimTools Plugins' started by Vef445, Jul 4, 2016.
  1. Vef445
    Vef445 Active Member
    Denmark
    597Coins
    It may happen to you the same as it happens to me with Dirt Rally: some values sent by the game and used for the calculation of Heave, Sway and Surge drop to 0 from time to time, which cause these three forces to bounce and make Simtool practically unusable for that game. See below video (only sway activated here):
    I suggest you give a try to the plugin attached to this message. It offers the same functionality as the other plugin available on this forum plus a filter on Heave, Sway and Surge.
    The filter works as: if sway and surge = 0 then use previous value for sway, surge and heave. Since it is impossible to have a real 0 on both sway and surge at the same time in a rally game without this zero to be generated by an error, then we won't lose any values.
    Motion data:
    This plugin provides pitch, roll, yaw and surge, sway, heave acceleration and traction loss.
    DashApp Data:
    Speed, Gear, RPM
    /!\ Important: This plugin uses more resources than the original plugin, you should run GameEngine as Administrator to avoid crashes.
    Please test and let me know if any problem.
    [Update] Version 0.2 available, you don't need to edit any xml manually anymore
    [Update 17/07] Version 0.4 available: GameEngine shouldn't be crashing anymore
    • Like Like x 7
    150,578Coins
    +11,017 / 55 / -2
    Nice one, I am looking forward to giving this a run :thumbs
  3. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Hi @Vef445 - Just by way of feedback, I tried this on my rig and after about 2 minutes it would cause GameEngine to error out and quit. Putting the original plugin back, and GameEngine is fine.
    It might be my setup, or the plugin is specific to people with the Zero issue. I just tried it out of curiosity as my movement is fine with the usual plugin.
  4. Vef445
    Denmark
    597Coins
    @Archie , just launch GameEngine as Administrator ;) (added in the first post, thanks for testing by the way) :)
  5. Vef445
    Denmark
    597Coins
    New version available (see first post): the patching process will adjust your hardware_settings_config.xml file automatically
  6. SilentChill
    20,582Coins
    Would like to try this for simtools v2.0 :)
  7. Boomslangnz
    4,167Coins
    ah well done man, i actually noticed this a couple weeks ago and told some people including @value1 but never heard back regarding it. It did make it practically unusable, however i thought it was just our 2.0 plugin that was a bit funky
  8. Vef445
    Denmark
    597Coins
  9. Vef445
    Denmark
    597Coins
    Plugin updated! :)
    Thanks @SilentChill and @value1 for your help. After starting on a new code-base and cleaning it up a little more, I could apply that filtering and get it to work without any crash of GameEngine.
    @Boomslangnz , give it a try :)
  10. fzxj520
    fzxj520 Active Member
    1,341Coins
    Install the plug cover, but SimTools does not receive any data,
  11. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    The same happens to me Heave, Sway and Surge drop to 0 from time to time, tomorrow im going to try this pluggin to see if it solves me. I have read many things about this error here but I could not fix yet
  12. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Nothing, i still have the same problem with Surge and Sway, im not receive movement of these forces, some help to fix it?
  13. Vef445
    Denmark
    597Coins
    I need to look into it. Been traveling a lot lately and didn't have much time to focus on the simulator... I'll keep you posted :)
  14. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Anything that can help, about my setup or whatever, you just have to tell me
    Thank you so much Vef445 I will be careful
  15. Vef445
    Denmark
    597Coins
    Better late than never... I've just tried the last updated version of Dirt Rally with my plugin and it works like a charm :)
  16. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
    Tried it with last version of Dirt Rally and I cant get speed and RPM info. Tried everything. Does anyone have a working settings?
  17. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Hey guys, Just getting Dirt Rally going on my new sim. I too am having problems with the input side from the game for Heave, Sway and Surge. It is at the point I just have these turned off as it only updates them maybe every 5 to 6 seconds with violent snaps lol.... Any thoughts?
  18. bodgy
    bodgy Member
    Australia
    86Coins
    So this plug in doesn't work with 2.0?
    I think I'm out of options to get sway, surge and heave. Pitch and roll feel awesome.
    I really got into this game while my sim was static recently and I was waiting to get a new motor controller. Devastated that I can't get motion happening properly. Racetrack based games seem so boring to me now.
    Any other rally games of this caliber I could try that have less problems with Simtools?
