Degree / Angle of movement for the Ball Joint.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Archie, Feb 9, 2015.
  1. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Hi Everyone,
    What is everyone's general experience when looking at how much movement a ball joint has in it?
    I am using open eye rose joints with spacers and I get about 18 degree's up and down from a right angle and about 15 degrees left and right.
    I was going to get some "real" rod ends / ball joints and looking at the data sheets for most of them anything between 18 degrees and 25 degrees is the max anyway.
    Wondering if it's worth getting them or sticking with what I have, and will I actually need that much movement anyway?
    150,728Coins
    +11,018 / 55 / -2
    What you have should be fine @Archie.
  3. Blame73
    Blame73 Well-Known Member
    8,300Coins
    In racing games I more like degrees on the front/back rather than on the left/right, cause I like feeling the acceleration/braking pair.
    Having too many degrees on left/right - at least in my rig - would shake me too much and would overheat my motors.
    I also think you should be fine
  4. Archie
    Wollongong, NSW, AU
    3,796Coins
    Thanks Guys!
