DC Motor Control Accuracy.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by SIN3R6Y, Feb 16, 2018.
  1. SIN3R6Y
    SIN3R6Y New Member
    Ohio
    137Coins
    So I've started my own 6DOF Stewart style project, most of the parts have still yet to arrive. I'm trying to plan out how to program the Arduino for controlling these motors with a Sabertooth controller.
    I'm assuming SimTools outputs a fixed position value per motor, for example something along the lines of a value between 0 and 255 with 127 being center position.
    Using limit switches and 360 potentiometers my idea is to have the Arduino test for top an bottom positions using the limit switches as end point points, then record the maximum and minimum values of the pot in memory as a reference for full bottom and full top. So something like full top / 2 would be theoretical center.
    The immediate issues that come to mind are debouncing the limit switches, which is likely solvable via a few ms delay on interrupt, and handling motor drift. Assuming the motor just dead stops as soon as you cut power is unwise, in the real world it will likely drift a bit. This can be an issue as the Arduino will try to hit a specific position point which the motor will likely overshoot by a very small amount causing the Arduino to pulse the motor back an forth between small values trying to get an exact position. How do you guys handle this? Adding a small error threshold?
    Secondly, motor ramping curves. Surely for small changes in position applying full power to a motor is not the best approach. I would imagine the right idea is to have some kind of ramping curve based of percent change in position?
    As a side note, dampers may help quite a bit with motor drift perhaps?
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
