Damaged JRK from welding.
Discussion in 'Motor actuators and drivers' started by bodgy, Mar 15, 2017.
  1. bodgy
    bodgy Member
    Australia
    86Coins
    I decided to move my arm mounting points further up behind my shoulders. I disconnected my hall sensors and motors but forgot to disconnect the pedals (G27 pedals removed from housing, so metal on metal contact with the sim frame).
    I now have a permanent (well not quite, it does go yellow sometimes and when it does I can play for hours) red light on the JRK when power is connected. I tested continuity through the pedal frame to the pot wires and to the USB housing on the JRK (both pedals and JRK were still connected to the computer via USB when I was welding and there is indeed a path from frame to USB housings.
    Am I safe in assuming that it was my negligence here that killed the JRK and there is nothing else sinister going on? I have tested for shorts on motor wires and on the hall sensor wires and found nothing. The working JRK will operate the motor and pot on the non working side of the sim no problem.
    So, just order another JRK and learn from my mistake? Or is there an easy to replace component on the JRK that might have blown I could try replacing (like a cap?), I'm not capable replacing the chips or surface mount stuff.
  2. Nick Moxley
    17,056Coins
    Not much to fix if you cant replace the main surface mount motor driver chip or the Voltage regulators. Are any of the chips burnt looking or Obvious signs of damage ?
  3. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,064Coins
    was it an AC welder?
  4. bodgy
    bodgy Member
    Australia
    86Coins
    Yeah an arc welder.
    I've ordered another controller, but am in contact with pololu to see if they have any ideas. I need a third for traction loss anyway.
  5. Nick Moxley
    17,056Coins
    darn Should have hit them up before ordering the replacement, Pololu is pretty good at offering 50% off when things like this happen. Ya could be your fault, but they still might offer it. You never know.
  6. Evan Rowlands
    Evan Rowlands EMR Industries
    business owner/ EMR industries
    Melbourne Australia
    - 82Coins
    hi mate im a motor mechanic/formula ford race mechanic ALWAYS and i mean ALWAY remove all electrical components before welding...when i work on the cars i have disconnect the battery both leads because when you weld your just making and ark to melt steel..sorry to hear you have damaged the board.. we live and learn bro im having issues with monster moto boards
