Question Considering going to 6dof. Very space limited. Size VS range?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Trigen, Jul 3, 2020.
  1. Trigen
    Trigen Active Member
    2,892Coins
    Hello
    I've been going down this rabbit hole for a while now and since im very space constrained i've discounted the thought of ever doing a 6 dof platform. Since i do fly and drive it would be a good thing to build and looking at it though it shouldnt really take that much more space?
    Currently i got a P1x from simlab and when i put the SFX100 on it it will be as big as i can go The space i got to work with is about 11.4m x 1.4m but i can move it slightly into the room if i put it on casters. Perhaps just a couple in front and use a lever to move it around.
    Im curious what the smallest for factor one could get away with and still have a good range? Will 150mm be fine? thats the range of my SFX and it would be good to re purpose as a folding belt drive if needed. Might sell them and go Silent chills route too
    Also there is the stiffness. its not super important but since i have a Simucube 2 direct drive it needs some stiffness.
    Has any of you gone down this route? How is Yaw/ traction loss on a 6 dof with small range?
    154,750Coins
    +11,196 / 57 / -2
