Comunication with Siemens S7-1200
Discussion in 'SimTools compatible interfaces' started by aveamon, Dec 2, 2018.
  1. aveamon
    aveamon New Member
    68Coins
    3DOF, AC motor, Motion platform
    Hi, im new there;)
    Im searching for Software which i can use with my s7-1200 simulator built.
    I must connect to PLC using network(Wireless bridge).
    Did any of you connect SimTools with s7-1200 via net?
    Can i use NET Interface for this, is this like UDP based?
    Another question, can i establish connection with PLC without license just for testing purposes, even without play;)
  2. Simulador de carrera
    Simulador de carrera New Member Gold Contributor
    103Coins
    3DOF, SCN6
    I need the same. Looking for connect a PLC to control siemens or festo actuators. I need for my final project in the university.
  3. zapata_h
    zapata_h Active Member
    Industrial Maintenance Manager
    España
    308Coins
    3DOF, AC motor, Arduino
    The conxion has to be exclusively with a plc?
  4. yobuddy
    51,535Coins
    Yes the Net interface is UDP.
    If you install SimTools without a license, it will run in demo mode with the game Live For Speed.
    Give it a go!
  5. dddman
    dddman New Member Gold Contributor
    193Coins
    You might be able to install nodeRed on your computer with a S7-link plugin to interface to your PLC
