Can't get game output data
Discussion in 'DIY Motion Simulator Projects' started by Frank1999, Sep 8, 2021.
  1. Frank1999
    Frank1999 New Member Gold Contributor
    48Coins
    4DOF
    Hello guys,
    Recently, I buy a new computer for test my 3Axis simlator. The OS is win10 home version. I meet a problem. Whatever I do, it can't get game output data. I test LFS, the axis testing is OK, but virtual axis running nothing.
    The same configuration is worked on my old win7 computer, but win10 didn't work.
    I attached the Cfg file. Please, can anyone help me?
    • cfg.txt
      File size:
      3.8 KB
      279
    154,400Coins
    +11,181 / 57 / -2
  3. Frank1999
    48Coins
    4DOF
    Thank you, @noorbeast , follow your replied thread, the problem is solved sucessfully. You save me, manhug:
  4. Deeppl
    Deeppl Member
    278Coins
    2DOF, DC motor, Motion platform
    Hehe. I also wasted a lot of time on this. And it was enough to read the instructions carefully. :) Why do you need to drive first and then the patch? Good luck!
    154,400Coins
    +11,181 / 57 / -2
    Running a race generates some required files needed to properly patch for motion.
  6. Deeppl
    Deeppl Member
    278Coins
    Need to do it with each game? Or only LFS?
    154,400Coins
    +11,181 / 57 / -2
    From memory only LFS, though other games have their own setup quirks, like Codemaster game patch path being different for 32 or 64bit Windows: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
    So make sure you read the install notes for each plugin on its Downloads page, plus be aware ogf the FAQ Game Tips and Fixes: https://www.xsimulator.net/community/faq/game-tips-and-fixes.19/category
  8. Frank1999
    48Coins
    4DOF
    I installed the Dirty 2.o plugin yesterday and one time success. Perfectly, thank you @noorbeast and everyone's amazing work.
  9. Deeppl
    Deeppl Member
    278Coins
    Good to hear that, I'll be trying to get it started tomorrow. You had any problems, you can give a hint
