Calculating the weight lift
Discussion in 'Electronic and hardware generally' started by MagicMike, Jan 28, 2014.
  1. MagicMike
    MagicMike New Member
    961Coins
    Assume that you have 3 motors 12v - 15A. How you can calculate how many kg your sim construction can lift with safety?
    The weight of the human is 80kg
    The weight of construction 7kg
    The weight that the motor wants to lift up 3kg
    ..So the total weight is about 90~ kg
  2. MagicMike
    961Coins
  3. bsft
    Depends on the frame design, if its a 2DOF pivot, most of the weight is balanced on a point and the motors move it back and forth off centre, so even wipers will move a 110kg person on a seat mover or a light full frame.
    If you are going into full lift of frame and person, thats where it gets a bit tricky.
    Mind you , there is a 6 x wiper 6DOF in testing that lifts 90kg easy in progress.
    What frame did you have in mind?
  4. value1
    14,516Coins
    3×12V×15A = 540 W
    Assuming an efficiency of 60% you have around 300W power output.
    With P = m × g × h / t and m = 90 kg, g = 9.81 m/s² you can lift the 90 kg about 35 cm in 1 sec.
    • Informative Informative x 4
    • Useful Useful x 3
  5. CalSim
    CalSim building things
    bacteriology analist
    Spain
    1,309Coins
    DC motor, Arduino, JRK
    @value1 Please repeat that calculation with my numbers, im amazed, hahaha
    6 motors 24A constant 48A peak 12v, 120mm Dia pulleys, how many kg would it be able to lift?
    I dont really understand the h/t on that formula, speed? where does it comes from?
    Edited: got 0.35 with 300kg 1036w/(300*9.8)=h/1
    h=0.35 m/s supossed 35cm/sec the same that him, why?
  6. Ponch
    Ponch New Member
    289Coins
    @CalSim , in the @value1's calculation the watt per kilogram ratio is about 3.6 W/kg.
    In your 6DOF, the ratio is about 3.4 W/kg (6.8 W/kg peak), so it is not strange to find similar results.
  7. value1
    14,516Coins
    The potential energy that you need for lifting the platform 35 cm is:
    Epot = m×g×h = 90 kg × 9.81 m/s² × 0.35 m = 309 J
    When you lift your platform in 1 second, the power required is P = Epot/time = 309 W
    P = 6× 24A × 12V = 1.728 kW. Assuming that the efficiency of your motors is 60 % you have 1 kW power available.
    Please keep in mind though, that in many cases, not all 6 motors will lift up at the same time!
