Lesson Cable (AWG) size Calculator.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Archie, Jan 29, 2015.
  1. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    First off, thanks to @noorbeast for a general guide on cable gauge which set me off on my little AWGhunt...
    I then went hunting around the Uberweb because we sim builders don't use nominal runs of cable, and the distances are quite short. Shorter cable - bigger burst.
    http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
    Using this calculator, you enter your Peak AMPS you expect a motor to draw, and enter the length of cable between Motor and JRK / MM etc.
    For example, to push 12V/40A over a cable that is only 20cm (0.2M) in length, you can get away with 17 AWG size.
    Disclaimer: General guidance only! :p
    • Informative Informative x 3
  2. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Nice was only thinking of what wires best to use on my build thank you :thumbs
