Question Budget motor for Direct Drive?
Discussion in 'DIY peripherals' started by WatchDoge, May 20, 2020.
  1. WatchDoge
    WatchDoge New Member
    158Coins
    Hello, How viable is using MY1016, 1020, 1025 for a Direct Drive? Will any of them produce enough or any amount of torque to make them a viable option without belts and ratios.
    Some sources claim 1016 has 5Nm of stall torque(correct me if I'm wrong) and you can overdrive them.
    I've looked around this forum and some use them with belts and some without, some recommend 16 or 20.
    If not direct drive , does belt driven setup perform well ?
  2. Gadget999
    12,349Coins
  3. WatchDoge
    158Coins
  4. Gadget999
    12,349Coins
  5. WatchDoge
    158Coins
    Sorry if I sound rude , but I've read that post before and there was an on going debate about my1016 and 1020 and maybe glossed over the last point made there . And it was posted 2017 , so I thought maybe someone will update me on the situation or give some tips or feedback. And there were some Designing a belt driver setup .
    And you yourself gave advice of using 2 of them.
    Could you please give ~amount of Nm from a direct setup you are running , or Amps( if its possible of course) ?
    Or at least is it worth it to make a 1016/20 DD setup ?
    Thank you
  6. Gadget999
    12,349Coins
    i don't know the torque of the wheel
    but you can work it out
    find the stall torque of the 1kw version of the motor (i think 3.2 nm)
    divide it by the radius of the steering wheel and you can calculate the torque yourself
    i don't recommend a gear and pulley - it will dull the sensitivity of the wheel
    if the motor is not powerful enough - use 2 of them !
    (or use a smaller steering wheel ;) )
    in reality people order a powerful sim wheel and have to turn it down to get a realistic feedback
    I watched a video where a racing driver tried an OSW - he had to turn it down to 30% to get it to feel realistic !
    unsure of your wheel diameter but
    if you used a 400 mm dia wheel and you had 3.2 nm motor torque
    3.2 / 0.2 = 16 NM torque at the wheel
    you have to learn this stuff to work it out
    if you want to guarantee a good wheel buy a OSW that is pre built
    if you want to have some fun build your own !
    (Things have moved on since 2017 and Thanos has just built a board that uses the Disco board with a servo motor- neat and simple solution. I am planning to build one soon enough)
  7. WatchDoge
    158Coins
    Thank you very much . I know about the 30% ffb thing , I don't intend to run it too hard , but I was curious about the torque of the motor itself . And if you are saying its performing well then I appreciate your feedback.
