Best Screen angle for triple monitors?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Muzza, Jun 2, 2010.
  1. Muzza
    Muzza New Member
    Sunshine Coast Australia
    Hi guys,
    Ive just bought 3 Samsung 27 panels to run with Eye Infinity and wanted to know what the optimum screen angle is for the side monitors..
    Ive read that 60 degree's is good but wanted to check here first as I thought that seemed a bit steep?
    Thanks in advance.
    Murray.
  2. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    with 27 panels i mean 45 degree is better. with 42 or 50 panels 60 degree is better.how many way you have between the screen and your head?
  3. Muzza
    Muzza New Member
    Hi Nima,
    My centre screen will be approximately 800mm from my face.
    How critical is the final angle as far as gaming performance is concerned? Is one particlar angle going to provide a better experience than another?
    Murray..
  4. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi
    i mean between 30 and 45 is the best for 27 panels and 800 mm face to screen.
  5. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    It really depends on the game you are running and your personal tastes...
    Besides IRacing and Live for speed, I don't know any other game that really supports screen angles. And support is a big word, the image will still be distortioned on both sides monitors no matter what angle you use since it's impossible to reproduce a perfect peripheral vision with flat panels ... There is no magic number and all the games reacts differently in my opinion.
    The distance between your eyes and the center screen will more define the correct FOV to use then the angle ...
    You must do some testing and adjust the FOV and monitor angle to suit your personal taste for optimal immersion.
    Again, that's my personal opinion ...
    Bleco
  6. netwizrm
    netwizrm Member
    Worcester MA 01605
    - 10Coins
    Hi
    Its true; the angles will vary, but also more importantly you mentioned using Eyefinity, I believe that ATI technology has a Bezel compensation feature with will help with the distortion and alignment from screen to screen.
    maybe Bleco elaborate or add on.
    Thanks,
    Robert
  7. bleco
    Montréal, Canada
    258Coins
    Yes Bezel compensation was the main add on to ATI catalyst 10.3 and is a great feature.
    Here are some infos from AMD website:
    ATI Catalyst Control Center™ version 10.3 and higher includes a bezel compensation tool that helps eliminate the distortion caused by the bezels of displays being used together by compensating for the physical space between them - so visuals and text appear to “go behind” the bezels.
    The bezel compensation tool presents a triangle pattern across the bezel and a widget is used to adjust the bezel compensation until the edges of the triangle line up across the bezel. In bezel compensated mode, pixels are removed that should be obscured by the display bezels. These pixels are rendered into the frame buffer, but not scanned out to any of the displays in the Display Group. Without this feature engaged, rendered objects will appear to “jump” across the gap between displays.
    Note: Bezel compensation only works in Single Large Surface (SLS) mode with monitor groups that have a pixel resolution and density within a 5% tolerance of each other
    It does not help for image distortion due to side monitor aggressive angle adjustment... maybe something will be added to a futur driver release ...
    Here is a vid of bezel compensation adjustment:
    http://www.youtube.com/watch?v=BFMgb3PBkBQ
    Bleco
