Bajer E Stop
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by BDZ, Jun 10, 2020.
  1. BDZ
    BDZ New Member
    166Coins
  2. Dschadu
    Dschadu Active Member
    1,935Coins
    Please be aware that the diagaram in the link you posted is not a suitable E-Stop!
    An E-Stop has to be NC, not NO! If your wire breaks your E-Stop will be useless!
    It's always best to use used industrial hardware for this (like a PILZ E-Stop Relais) and cut the power completely. A software solution can only be an addition.
    To your original question: as far as I'm aware, the odrive only has a software e-stop command via CAN (which is even not the highest priority...)
