value1
Assetto Corsa Plugin 2.0.7.1
SimTools plugin for Assetto Corsa
  1. value1
    14,182Coins
    Assetto Corsa Plugin - SimTools plugin for Assetto Corsa
    I just moved the plugin so that there is a Discussion Tab available. This was not the case with the old resource (plugin)
  2. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,053Coins
    Arduino, 4DOF
    Is it a UDP plugin ? If so, I'll try on PS4 tonight :)
  3. value1
    14,182Coins
    Nope, it's using SharedMemory. But I have PM'd you the source for the UDP plugin :)
  4. vthinsel
    FRANCE
    6,053Coins
    Arduino, 4DOF
    And I'll check tonight if it works ! If it works (which I'm pretty sure) we will see how we can make a UDP plugin :p
  5. vthinsel
    FRANCE
    6,053Coins
    Arduino, 4DOF
    Well.... I did quite a few tests on AC running on a PS4. The issue I'm facing is that you need to register each time you start a race mode. I'll have to make something smart to register and manage handshake when needed. Beside this I was able to get UDP data with no problems. The UDP data is available on the github repo , in case you want to replay it https://github.com/vthinsel/Python_UDP_Receiver
    The UDP plugin will take me some time I'm afraid, but its worth doing it !
    • Useful Useful x 2
  6. Brett
    Brett Member
    Engineer
    Carrum Downs Victoria Australia
    156Coins
    2DOF, 3DOF, JRK
    @value1,
    I notice the latest version 2.0.4.2 now has inputs for the 3 extra axis, labelled Traction Loss LV, Traction Loss V18 and Traction Loss Direction. Can you please explain what each of these actually read?
    Thanks in advance.
  7. john thornewill
    john thornewill New Member
    232Coins
    DC motor
    Hi - is it just me (entirely possible), but is this broken now with the v1.13 upgrade released last night? I presume there isn't some sort of setting in the game itself I need to enable to get shared memory working?
    Cheers John
  8. vthinsel
    FRANCE
    6,053Coins
    Arduino, 4DOF
    Hum..... my UDP plugin is now finished. I just need to package it. If you want to be a guinea-pig, just PM me :)
  9. SeatTime
    No, mine works fine - new Mazda cars in the Garage - have not done anything to the old settings :).
  10. Nick Moxley
    17,057Coins
    Lol Stefano would have to essentially have one of his cats Copy and paste a Large section of code and walk on the delete key, then somehow magically hit compile said Code and Miraculously it compiled ok, then It would need to be pushed to Steam by cat #2 to patch over to a Steam build.....Then would need to press the Big "GO Live" Button to make it an official patch.
    or there's something wrong on your end.
    :grin:grin
    Jk, let us know if you need a hand or what you are experiencing and we'll get you through it.
  11. vthinsel
    FRANCE
    6,053Coins
    Arduino, 4DOF
    If only cat#3 could add yaw/pitch/roll and make sure the RTLap is sent from consoles that would be awesome !
    Still stuck with RTLap on PS4 :( . No RTLap, no leaderboard.
  12. Nick Moxley
    17,057Coins
    Have you tried talking with Stefano ?
  13. vthinsel
    FRANCE
    6,053Coins
    Arduino, 4DOF
    Well, I do not know him. I just made some posts on different forums, but nothing yet. If you could relay the request I'd be more than gratefull.
  14. Nick Moxley
    17,057Coins
    Get me a legit explanation of the issue and what you need and I will pass it along directly to him. ;)
  15. vthinsel
    FRANCE
    6,053Coins
    Arduino, 4DOF
    Thanks. To make sure, Ill try to test on a PC version the same code and see if it behaves differently. Ill then try to be clear and short in my report.
    Next will be in PM. Sorry for off-topic
  16. Brett
    Brett Member
    Engineer
    156Coins
    2DOF, 3DOF, JRK
    Does anyone that's using using traction loss know?
  17. value1
    14,182Coins
    Extra2 and Extra3 is debris from debugging. Ignore it and just use Extra1 ;)
    • Informative Informative x 4
  18. john thornewill
    232Coins
    DC motor
    Hi all - This is really weird and frustrating, but my office PC works find with the patch, but my home PC doesn't seem to recognise that Assetto Corsa is running. I've downloaded the latest patch and tried patching and re-patching multiple times, but it just won't recognise the game.
    What am I doing wrong here? Project Cars works fine on this PC as does Elite Dangerous, but AC just isn't having any of it...
    Assetto Corsa is V1.13.2...
    Cheers John.
  19. john thornewill
    232Coins
    DC motor
    Hi - also the patch version is 2.0.4.2...
  20. john thornewill
    232Coins
    DC motor
    Fixed it myself! In Assetto Corsa, if anyone else has the above problem, In AC settings, turn on and then off 32 bit support!
