ASSETTO CORSA 1.3 problem
Discussion in 'SimTools Plugins' started by gilou30, Oct 15, 2015.
  1. gilou30
    gilou30 New Member
    Fournès
    306Coins
    I have a little problem.
    I installed the 1.3 release of Assetto Corsa via Steam and since simmtools unbootable with the game. I had the version (unofficial) 1.2 and everything functioned well. I did everything as it should, but simtools does not turn blue. Can someone help me please
  2. value1
    14,509Coins
    Did you patch the game? From your description I assume that is a new installation.
  3. gilou30
    gilou30 New Member
    Fournès
    306Coins
    Yes ! But ...
  4. Pit
    30,416Coins
    Assetto is running in 32bit compatibility mode?
  5. gilou30
    gilou30 New Member
    Fournès
    306Coins
    Assetto is in 32 bits
  6. Pit
    30,416Coins
    you must use the 64bit mode.
  7. gilou30
    gilou30 New Member
    Fournès
    306Coins
    How to make ?
  8. Pit
    30,416Coins
    If you do not know what is to do - then AC is already running in 64bit mode :D
    ---please can you check the settings within AC - there must be sometning like "32bit compatibility mode" - this has to be unchecked.
  9. Nick Moxley
    17,054Coins
    Yes there is a "FORCE 32bit" in the AC option's now.
  10. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    I have a different problem, AC was working perfectly with dream Pack1, downloaded DP 2, all the cars were installed I did a quick play and they seem OK, but no Catalunya anywhere, I've had a bit of a look around but don't really have a clue any advice guys?? If it needs downloading again how do I tee it up with steam?? It's got me buggered!!
  11. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Rastus,
    "Me" thinks it's called Barcelona ????? as I looked for Catalunya also and didn't find it.
    I'll look again tonight to make sure.
    Tom
  12. Blame73
    Blame73 Well-Known Member
    8,255Coins
    Also, you could check game integrity from your library, game properties
  13. Nick Moxley
    17,054Coins
    No problem, Tracks called Barcelona. Not Catalunya
  14. Rastus
    Sydney Australia
    11,518Coins
    DUH!......@cthiggin you're right Tom Barcelona right there in front of my glazed eyes, guess I'm getting (no am) old and confused, maybe the onset of "Old Timers". Thanks mate for the guiding hand!!
    • Funny Funny x 2
  15. Rastus
    Sydney Australia
    11,518Coins
    Thanks to you also @Nick Moxley, I read Tom's reply as it was ahead of yours, dashed straight out to the rig found the track in question came back and replied, then found your reply next in line, just more proof I 'm losing it!!ROFL
  16. gilou30
    gilou30 New Member
    Fournès
    306Coins
    I uninstall and reinstall everything and it still does not work ...
  17. noorbeast
    145,148Coins
    +10,780 / 52 / -2
    When you say 'everything' what do you mean, the plugin, the game, SimTools or all of them?
    To aid troubleshooting you will need to be far more specific about what you have or have not done.
    Often pictures of all settings are most helpful.
  18. gilou30
    gilou30 New Member
    Fournès
    306Coins
    Steam, assetto corsa, simtools, plugin
  19. noorbeast
    145,148Coins
    +10,780 / 52 / -2
    So you have re-patched the game?
    Does the sim move OK in Output Testing?
    Does the Game Manager turn blue and say Connected when you run AC?
  20. gilou30
    gilou30 New Member
    Fournès
    306Coins
    I have re-patched thé game. The sim move OK output testing. Game manager dont turn blue ans say connected when i run AC
