Are these Motor any good?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Fluke, Feb 27, 2018.
  1. Fluke
    Fluke Member
    Stafford, United Kingdom
    822Coins
    I was originally going to buy 3x 24v 400w motors from Simukit and they were rated at 50rpm are 57nm, I have now found these 500w motors. They are slightly cheaper and the 110ZYT156 with NMRV50 gearbox at 50rpm are 82.5nm.
    https://www.alibaba.com/product-det...m=a2700.8293689.scGlobalHomeHeader.373.x7chYc
    Are these likely to be a better motor? Or have I read it all wrong?
    BTW - They will be used in a 3dof build with 24v 1000w power supplies.
    https://simukit.com/alimentations/11-alimentation-24v-1000w.html
  2. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Hi Fluke, as you do net get an answer here: Have you selected some motors now and which ?
    I am also struggling to find the right motors (or better for which motors I have to look for).
    Unfortunately there seems to be no "rule of thumb' like: If your full frame is 120 kg and should move by max. 100 mm, you should get a motor with x Watt, y rpm and z Nm torque.
