Arduino UNO diagnostic code or feature ?
Discussion in 'Electronic and hardware generally' started by speedy, Mar 5, 2017.
  1. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,942Coins
    HELP Guys ...
    I suspect my Arduino UNO behavior as it was running the SMC3 code for a good amount of time now ... But suddenly it gave me an unexpected movements to 2 of the motors as they stopped and became working again then suddenly one completely stopped again and the other keeps going down to the max. limit and stops without any obvious reasons ... the third one is working good all the time .
    Loaded and reloaded a fresh code didn't solve the problem .
    Any suggestion code/diagnostics to test the internal block structure of the UNO ?
    Is the Blink code is enough ? any thing in the IDE library ?
    Thansk ........... :)
  2. That Dude There
    That Dude There Member
    USA
    430Coins
    Any luck getting this figured out?
  3. speedy
    Alexandria , Egypt
    7,942Coins
    Unfortunately I needed much more easier way to diagnose the system but there is nothing helpful ...
    I'm going to the hard way testing each motor connections separately with the known working good motor 3 to see where the error is coming from ...
  4. Vagner
    Vagner New Member
    Brasil
    - 99Coins
    [QUOTE = "speedy, post: 128239, member: 6452"] AJUDE Guys ...
    Eu suspeito que meu comportamento Arduino UNO como ele estava executando o código SMC3 há uma boa quantidade de tempo agora ... Mas, de repente, me deu movimentos inesperados para 2 dos motores quando eles pararam e voltaram a trabalhar novamente, de repente, um completamente parado de novo e o outro continua a diminuir o máximo. Limita e pára sem razões óbvias ... o terceiro está funcionando bem o tempo todo.
    Carregado e recarregado um novo código não resolveu o problema.
    Qualquer código de sugestão / diagnóstico para testar a estrutura de bloco interno do UNO?
    O código de piscar é suficiente? Qualquer coisa na biblioteca IDE?
    Thansk ........... :)[/ QUOTE]
