Showroom Arduino FFB-wheel with pedals
Discussion in 'DIY peripherals' started by dr.feelgood, Sep 6, 2020.
  1. dr.feelgood
    dr.feelgood Member Gold Contributor
    FINLAND
    478Coins
    Hi all!
    This is my second Arduino-wheel:
    -Arduino Leonardo, AI-wave software
    -MY 6812 e-scooter motor 24V-100w with HTD 3M-pulley, 14 teeth
    -HTD belt 15mm/486mm
    -Motor Driver BTS7960 43A
    -24V / 20A LED powersource
    -3D-printed bearing-housings
    -3D-printed 140 teeth HTD-pulley to wheel-side > 1:10 reduction
    -Welded frame, squaretubes, angled nailing plates, ...
    -70mm 12V fan with pwm temp-controller on motor (drilled holes for ventilation on it), 3D-printed housing
    -50mm 12V fan with ntc temp-controller on motor driver, 3D-printed housing
    - 24V to 12V diy DC-DC converter
    - 2000 p/r 'omron' encoder with non functional Z-signal > manual calibration
    - 10k pot for force-adjustment on left side + 4 push buttons
    -13" Old leather wheel from my ex. Datsun 510
    - 12mm threaded rod as wheel axel, plus nuts and bolts and ...
    Pedals:
    -Wooden base, with joga mat :)
    -Metal, nuts and bolts welded with square-tube and some 3D-printed things
    -Hall-efect / magnet on Throttle
    -Load-cell on Brake
    -Micro-switch on Clutch
    Wheel-pics:
    IMG_20200906_182746.jpg IMG_20200906_183823.jpg IMG_20200906_183736.jpg IMG_20200906_183757.jpg IMG_20200906_183809.jpg IMG_20200906_184015.jpg IMG_20200906_184029.jpg IMG_20200906_184046.jpg IMG_20200906_184055.jpg IMG_20200906_184114.jpg IMG_20200906_184135.jpg IMG_20200906_184159.jpg
    Pedal-pics:
    IMG_20200906_183844.jpg IMG_20200906_183914.jpg IMG_20200906_184150.jpg IMG_20200906_183928.jpg IMG_20200906_183948.jpg IMG_20200906_183956.jpg
    Very sort video how it handles on track... only 450 degree setting and ~60% force:
    Wheel has max resistance of about 6kg, measured from rim. If max power is used, power supply is a bit too small, i burned 15 amp fuse while testing. Also it motor gets hot.
    On normal rallying, force is about 40-60% of max. It kicks quite enough...
    Still doing some tuning and evaluating weather this is better or worse than my 1st wheel :)
