Arduino code for G seat H bridge?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Trigen, Jan 6, 2019.
  1. Trigen
    Trigen Active Member
    2,891Coins
  2. BlazinH
    16,689Coins
    I don't know if there is one anywhere on this forum for that driver. This one doesn't work the way your motor driver states to use it but it still may work with it in mode 2 https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/.
  3. Trigen
    2,891Coins
    Thanks this worked better. Mode 2. Im only able to get it to run one way though and im sure the connections are correct. If i use the tool and go a square it should alternate right? Also the same in Game engine Axis tester
  4. Trigen
    2,891Coins
    This script works fine and it runs both ways
    Code:
    const int pwm = 2 ;  //initializing pin 2 as pwm // EN pin
    const int in_1 = 3 ; // RPWM
    const int in_2 = 5 ; // LPWM
    /*const int pwm = 2 ;  //initializing pin 2 as pwm
    //For providing logic to L298 IC to choose the direction of the DC motor
    void setup()
    pinMode(pwm,OUTPUT) ;   //we have to set PWM pin as output
    pinMode(in_1,OUTPUT) ;  //Logic pins are also set as output
    pinMode(in_2,OUTPUT) ;
    void loop()
    //For Clock wise motion , in_1 = High , in_2 = Low
    digitalWrite(in_1,HIGH) ;
    digitalWrite(in_2, LOW) ;
    analogWrite(pwm,255) ;
    /*setting pwm of the motor to 255
    we can change the speed of rotaion
    by chaning pwm input but we are only
    using arduino so we are using higest
    value to driver the motor  */
    //Clockwise for 3 secs
    delay(3000) ;
    //For brake
    digitalWrite(in_2,HIGH) ;
    delay(1000) ;
    //For Anti Clock-wise motion - IN_1 = LOW , IN_2 = HIGH
    digitalWrite(in_1,LOW) ;
    delay(3000) ;
    //For brake
    delay(1000) ;
  5. Trigen
    2,891Coins
    Turned out to be a bad bridge and a dead one.
