Arduino C code
Discussion in 'Ready, set, go - Start your engines' started by lujanie, Sep 10, 2015.
  1. lujanie
    lujanie New Member
    96Coins
    Hi Guys,
    I would like to take a look on a C source code for Arduino that supports SimTools communication.
    I read some threads but I find only binary files.
    Where I can find sources?
    Thanks!
  2. BlazinH
    16,677Coins
    Hi there! If you open any of the arduino sketches found on this site with the arduino programming software you will be able to see properly formatted source code.
    Edit: That is, as formatted by the sketches author.
  3. RacingMat
    21,068Coins
    • Agree Agree x 3
  4. lujanie
    lujanie New Member
    96Coins
    Thanks!
  5. lukas12
    lukas12 Member
    Poland
    118Coins
  6. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    Thanks.
  7. Ivanir
    Ivanir radical simulation
    Brazil
    275Coins
    thanks for helping beginners to the forum
  8. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    Greetings which your order, 2DOF, 3DOF or 6DOF
    I still need this support?
  9. sunny_hk
    sunny_hk New Member
    250Coins
    I may soon look at those link too. hope that i can understand those code
  10. engenharia
    engenharia New Member
    Brasil
    231Coins
  11. fyywhy
    fyywhy New Member
    Chengdu,SiChuan,Chinese
    126Coins
    I would like to take a look on a C source code for STM32 that supports SimTools communication.
    Where I can find source?
  12. EL mansouri
    EL mansouri New Member
    - 49Coins
    bonjour avait vous des codes source
  13. drancope
    drancope New Member
    Baza, Spain
    170Coins
    I'm guessing there must be some libraries to work with each platform.
    Can anyone tell us where to search?
    I feel like I'm lost.
    Thanks.
  14. noorbeast
    153,065Coins
    +11,117 / 56 / -2
  15. Flymen
    Montreal, Canada
    2,462Coins
    DC motor, 6DOF
  16. noorbeast
    153,065Coins
    +11,117 / 56 / -2
  17. Progect555
    Progect555 New Member
    Россия
    233Coins
    Добрый день! Подскажите плиз Ардуино Uno оригинал будет работать на виндовс 10 64 бит, нормально ли установятся драйвера или лучше на виндовс 7 64 бит строить 2DOF платформу - мне под виар очки HTC Vive?! Зарание спасибо, я только начинаю проект
  18. noorbeast
    153,065Coins
    +11,117 / 56 / -2
    You can dual language post but do need to include and English translation, via Google Translate, as per the forum rules: https://www.xsimulator.net/community/threads/forum-rules.9527/
    Google Translation -
    Good afternoon! Prompt pliz Arduino Uno the original will work on Windows 10 64 bit, whether it is normal for drivers to be installed or better on Windows 7 64 bit to build a 2DOF platform - for me under Viar glasses HTC Vive ?! Thank you, I'm just starting the project
    Response -
    The Arduino will run fine on either but Win 10 will be better for VR.
  19. pinthi
    pinthi Member Gold Contributor
    - 119Coins
