AMC LCD showing 108 not 128
Discussion in 'New users start here - FAQ' started by stowaway, Jun 24, 2009.
  1. stowaway
    stowaway New Member
    Gold Coast - Australia
    1Coins
    My AMC LCD is showing 108 108 not 128 128 like on tronics videos... (for the values that are suppose to be changed by the computer.. not the values the pot changes)
    would this indicate a problem?
    Also when i turn my pots they go from a random number between 0-100 and 863...
  2. stowaway
    stowaway New Member
    1Coins
    Well im making progress! i changed the chip to a atmega8535-16PU (i had 16PC .. )
    And it now comes up with 128 128 !!
    however still doesnt talk thru USO :( i will keep trying!
  3. stowaway
    stowaway New Member
    1Coins
    I also noticed that hyper terminal looks like it works! but it wont allow me to enter any input into it. so it effectively doesnt work.
  4. wannabeaflyer
    wannabeaflyer Active Member
    UK - London area
    973Coins
    Dont Give up we all have been there i cant say wher for sure but can you read the Checksum when you have programmed the Atmega chip , have you set the correct fuses, is there a Loose connection ,dry joint or intermitant contact in the Proramming jumper cable , i had all these issue on my build and i thought i had checked those area's loads of times , i guess the moral here is We Know the Circuit works it useually then a small mistake on the builder Side not a critisism just what i have picked up reading some of our posts, but being so close to the build you tend to not see your own mistakes. that was very much the case for me. so fingers crossed Good buddy hang in there, your gonna scream when it works and thats a good thing
  5. stowaway
    stowaway New Member
    1Coins
    I definitely wont be giving up!
    Ive decided that my hacked together board has had too many repairs and re-repairs. and it wasnt a quality pcb build in the fist place. (i used the iron on method)
    Im going to try the UV Light method and hopefully Ill get a better quality board.
