Add Traction Loss to Seat Only
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Ken Boekhaus, May 19, 2021.
  1. Ken Boekhaus
    Ken Boekhaus New Member Gold Contributor
    - 114Coins
    Has anyone built a 3 DOF motion platform and added traction loss to yaw only the seat? It would seem to require less of an actuator, less structure and be cheaper to build.
    153,788Coins
    +11,150 / 57 / -2
    Yaw, which rotates around a central point, and traction loss, which pivots near your feet, are 2 different forces, so can you clarify a bit more, perhaps including a sketch of what you have in mind.
  3. Ken Boekhaus
    - 114Coins
    It’s just an idea at this point. I originally envisioned using a gaming desk chair with the base cut off. It wouldn’t take a lot of force to rotate the chair on its bearings. After your comment about yaw rotating about the feet, I need to rethink the hinge point.
    Thanks for your reply.
    153,788Coins
    +11,150 / 57 / -2
