AC + CM oculus trouble..
Discussion in 'Assetto Corsa' started by Martyn, Jan 5, 2020.
  1. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Hi i have strange problem using Oculus Rift (CV1) and AC with Content Manager.
    I´m using all my setup for maybe two years already without any issues, but now it went broke from day to day.
    When i start my computer i can run maybe two or three races in single player / practice but then trouble comes. In online i ´m unable to do even one more race.
    I start the race via content manager, when the race loads on monitor it is ok, VR tracking works, sound in oculus works but THERE IS NO IMAGE in VR - i can only see oculus dash, no assetto:(
    I´ve found few more people on reddit with the same problem but no solution..
    I tried reinstalling oculus software (really genial where you have to download 7,5GB for every install), i even tried oculus homeless hack, i tried running oculus app and content manager as administrator, but no help:(
    Anybody have an idea, please?
    Thanks!
  2. PairRoc
    PairRoc New Member
    China
    190Coins
    2DOF, SCN5, SimforceGT
    "Oculus Rift might not work properly with Content Manager in AC root folder.It's better to move it somewhere else to avoid potential issues."says in CM
  3. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Sure i know this, but that was not the issue.
    Problem is when i start ac server, then oculus do not work. Without server running it works fine:)
  4. Blackflam
    Blackflam New Member
    - 19Coins
    When i want to play AC in VR, i start my oculus and i go in desktop mode. And after, i start CM. It's work perfectly for me.
  5. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    The problem was completely different (and is solved now).
    From some mysterious reason it is impossible to play in oculus vr while running ac server on the same machine..:-o
  6. Blackflam
    - 19Coins
    OK, it's good for you, it's the more important. It's mysterious. In CM you have an option to load setting for race, hotlap or online. When you launch online, CM load maybe the wrong vidéo setting.
  7. lysa elec
    lysa elec LYSA ELEC
    16Coins
    the is not probleme with content manager and gog resuls with quest 2
  8. lysa elec
    lysa elec LYSA ELEC
    16Coins
    i have problem with oculus and keyboard witch change of language
