Showroom 6DOF Stewart AC Servo Motion Helicopter Simulator Build
Discussion in 'DIY Motion Simulator Projects' started by GettinBetter, Apr 15, 2024.
  1. GettinBetter
    GettinBetter Magna Merchant Gold Contributor
    CAD Engineer
    Kent, UK
    746Coins
    Just before I finish the base, I wanted (as mentioned before) to assemble it all with rubber boots on the rod ends (i.e. heim/rose bearings).
    I looked at many options online, and nothing I found made me happy and as far as I'm aware, there are no boots for the female version of the bearings. I'm sure they're out there but prohibitively expensive, or stupid delivery times.
    I bought a few of the offerings, on offer, but they turned out to be IMO, rubbish.
    So I'm working on this. It's not quite there yet, (I need to get the clearances closer to acceptable) but I've broken the back of it, and will tweak it tomorrow, before making a test mould.
    I've bought a 2kgs of resin (to last over xmas), and a 1kg tin of liquid silicone rubber, so it's just a matter of a little more work.
    I didn't want to finish the base and not be able to put it all together all greased up with dust covers.
  2. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    More resin arrived today, but I did have enough to try a set of mold parts to explore.
    First inner part (which I called the plug) I printed on it's side, as it doesn't like surfaces that eminate out into fresh air (well liquid resin actually) with no support, and although I added supports, it was a mess really.
    The second was printed standing up, with stronger supports, which was quite successful.
    The mold casing (times 2) printed just flat on the table, finished with no problems.
    This exploration lead me to tweak clearances, make the sealing ribs larger and add a few more features.
    I'm about to print another set of these, and attempt a first silicone pour.
    I plan to assemble the mold, and pour in the silicone in the funnels (which enters the mold at the bottom, hopefully to eliminate/minimise any air bubbles), untill I see a witness at the four smaller holes.
    If there is any problems with air bubbles, I will see if I can utilise my ultrasonic cleaner in some way to vibrate it? Well thats the plan anyway.
    :popcorn
  3. NickD
    NickD Member
    277Coins
    I am so impressed with the skills and drive that so many members here have. Fantastic work! :thumbs
  4. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    I haven't had too much spare time for rapid progress, but I have been snatching time between work and chores etc, to do some bits.
    The dev stockpile is building up. :think
    Quite a learning curve going on here. :nerd
    I did a first pour knowing full well it wasn't going to be perfect, but I was keen to play with the silicone, to get a feel for what to expect.
    My smallest container with measurements down the side was 60ml, and the catalyst was 3%. So guestimating the 3% and 3% of colouring pigment meant the silicone ended up taking a week to fully cure. Obviously I got it wrong, which prompted me to buy some pipettes.
    Having struggled to brush the silicon grease on as a releasing agent, I was prompted to buy some spray on releasing agent.
    The first pour was a disaster, the viscosity was such that I had to fill the sprule funnels and set the timer on my phone to 30 mins to come back and refill. After about 3 or four hours, teh remainder of the 50ml mix was begining to coagulate, so I called it a wrap.
    It seems the parts are suffering from Z axis shrinkage, which I later found out after cutting the mold in half.
    The black pen mark is almost touching the casing. :(
    The printer is currently printing a casing with low shrinkage resin..
  5. NickD
    NickD Member
    277Coins
    I'd say that's really promising results to start. Were you able to test fit what you made there or is the shrinkage too much making it too tight?
  6. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    The shrinkage during 3D resin printing of the mould, made the wall thickness of the silicone rubber too thin.
    Other issues were:
    • The rubber boot orifices were to large and didn't grip the body of the rose/heim bearing, or the spacers. The diameters have been reduced.
    • The rubber took too long to pour, so I have drilled out the sprule holes to take piston type plungers, to push the rubber through the mould, this will allow me to add more catalyst and speed up the curing time.
    • The chosen shore hardness may be too soft.
    I've tried to address these issues in the coming prints.
  7. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    Almost there...
    Two issues to sort.
    • Force more rubber through the mould to expel the air bubbles (which seem to be at the beginning of the pour)
    • Grind the inner plug to create a thicker wall at the side centre walls.
    On first inspection as the mould was seperated, I was quite pleased with initial result, then I saw the air bubbles. The reduction of diameters meant the grip on the main body and spacers was adequate.
    As this was not going to be useable, I thought I'd check wall thickness, and preceded to cut it in sections.
    This highlighted the previous problem of printing shrinkage, and that the low shrinkage resin hadn't full solved the problem. The thickness in the area of the air bubbles was perfect.
    I've decided to grind the centre plug because the FEP membrane of the printer vat is leaking and needs changing.
  8. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    Ok, some progress. I am pleased to anounce the first successful bubble free silicone rubber casting. :D
    The secret to getting rid of the air bubbles was de-gassing. (putting the rubber in a vacuum chamber after agitating and putting all the bubble in it.)
    Now I started looking at all the kits on amazon, and was a bit reluctant to spend all that for 12 rubber boots.
    So my search term included DIY methods. During my perusal at the various kits etc, I saw what to me looked like a brake bleeding vacuum pump, exactly like what I have on my shelf, I rushed off to find it and blow me down, it had a larger (than I was previously using) container. In fact the perfect size for the amount of rubber I was trying to de-gass (when under a vacuum the rubber rises up the container, and so needs to be at least two or three times the size of the volume you are trying to de-gass).
    I'd not used it yet, so it was straight out the box. I did a test of the pressure, and after spraying a little WD40 down the pump shaft to ensure the seal was working efficiently, it reached the 29in Hg, as described in the YT videos.
    With my multi-modified mould, I did a de-gass (amazingly easy) waited for 5 mins to make sure it was fully 'cooked' and released the vacuum. The smoothness compared to the airated version was amazing.
    Images.
    Mould - now with added barrier around the top, because when you push the plungers down the rubber comes out of the air vents and without the barrier just goes everywhere.
    The smaller container was the original one that I was using, the larger one came with the bleed kit, which perfectly allowed the rubber to expand whilst de-gassing.
    Now to do another 11 :cool:
  9. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    Just received these beauts yesterday....
    I got fed up with so little progress, and instead of making them, I sent the model to an online CNC manufacturer.
    I still need to drill & tap some bits as I wasn't sure what size I will be using, but thats broken the back of the job, and with a little more work they be ready to put on the base.
  10. Aerosmith
    Aerosmith Active Member
    self employed
    2,987Coins
    3DOF, AC motor
    Wow, awesome. I think if you ordered those parts 10 years ago from a CNC manufacturer you probably would had to pay at least $1000. Or the manufacturer refused to do it at all unless you ordered at least 100 pcs. each (which would have costed much >$1000)
  11. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    This was JLC-CNC in China, Upload your 3D models and get an instant quote. I liked the final figure and went for it. We emailed back and forth to define tolerances, and 18 days later, they arrrived. Well happy with the results, and as a life long precision machinist, it's exactly what I would have produced, except I didn't have to lift a finger. I went for a harder aluminium for the spigot with the keyway in, and the softer one for the body, so that they wouldn't bind when sliding in and out, not that they'll get too much adjusting anyway. Price was a little over £500.
  12. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    Progress has been a bit slow, as I've been doing extra days at work, but things should pick up going forward now.
    Whilst doing extra work, and as it was hampering my personal progress, I thought I might hand a few bits over to them for manufacture, so the joy sticks and side seat covers are being done.
    The final (jeezz, I hope so) mould has been printed (had to get, and fit a new screen for my 3D printer).
    This version is a double cast, with a top vat to catch the extra rubber, and diameters will be machined to be perfectly round, to combat the ovality caused by shrinkage. I've spent far too much time on these boots, and it's causing a real bottleneck, but if this version works acceptably, it'll be onto the final fettling of the base frame.
    I've started assembly of the anti torque pedals, so there will be some pics of those when I get more done.
    I've also added some more parts to the 3D model, and have attached a download link for
    anybody that wants a look. (find the Bell206_Cockpit_Assembly-6.FCstd file )
  13. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    Machined out the holes which went well, even the whole lot falling out of the chuck, didn't deter my progress.
    Then went to machine the plug diameters only to find I hadn't left quite enough on them (or took too much out of the holes) and barely took a whisker off them, still that would have to do.
    Got pouring....
    Finally got them all finished plus a few spares, you know just in case.
    Tapped various parts of the pedals, and made up the links. Just a bush in the swiveling plate to make, and the nylon key to go and they're done too.
    Tomorrow I'm on the main platform frame to do the last few welds and a bit of fettling, and I can get the whole lot assembled. I'm on holiday this week, so can put some dedicated time into it.
  14. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    I thought I'd better check my loadings now that I've got a bit further.
    It's going to be a bit close, I may have to do what @Aerosmith suggested and get some higher ration gearboxes. I'll be fine with only one person.....
    I mean what actually happens when a servo cuts out? if the others continue it could put some unexpected/unallowed for, stresses on the system..
    I've added the spreadsheet, if you spot any irregularities, be sure to let me know
    Got the top frame back on....
  15. Aerosmith
    self employed
    2,987Coins
    3DOF, AC motor
    So 1:50 is the reduction ratio of the new gearboxes you plan to buy? What was the ratio of the old ones? I can calculate forces and speeds tomorrow... Wait before you order, if possible.
  16. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    50:1 are the ones I have now. Putting 70:1 in the calcs gives me ~485 kgs 'ish.
    BTW, all the estimated weights in my calc sheet are being very generous, so it may be under the figure I have ended up with.
    I don't plan on getting them yet, will need to save some pennies, as I think the price seems to have gone up?
    I would be very interested in your take on the calcs, but don't bust a gut, I'll hang on.
  17. Aerosmith
    self employed
    2,987Coins
    3DOF, AC motor
    Your calculations look good. With 200mm arm length, 750W motors and 1:50 gearboxes you can expect a force of 570N per arm and a max. speed of 1.25m/s. That means 6 motors can barely hold the weight of up to 348kg. But you need some reserve. Otherwise, if your load is slightly asymetrical because, for example, your passenger is a bit heavier than the pilot or you fly nose-down for a while one of the motors might get hot and could quit.
    Upgrading to 1:70 gearboxes would mean 800N per arm or 480kg total and 0.9m/s max. speed.
    Another option would be keeping the gearboxes and replace the motors with 1kW. There are two 1kW motor types, one with 3.2Nm and 3000rpm and the other with 4Nm and 2400rpm.
    4Nm and 1:50 means 950N per arm, 580kg and 0.71m/s.
  18. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    Thanks for that, it's always good to know you're on the right path.
    Interesting options, but I've just looked at the prices for the 4Nm version and compared to just changing the gearboxes it would add another £600~ to the order. Not to mention they're a lot longer, so I'd need to check there is enough room for them.
    4Nm would certainly give me the load margins and any speed increases (not convinced I'll need more speed).
    I'll carry on for now as its fine for one person, and if I sell my motorbike I'll have another look them. I'll also keep a close eye on all the weights of the parts I fit going forward.
    Still wondering what happens if one motor cuts out under overload condition? Need to check the manual for servo outputs that can be used to trigger an E. shutdown.
    I also thought I might build one of these for the radio stack.
    https://flyingforfun.weebly.com/diy-radio.html
    I have bought a touchscreen for them but finding the specific software for the radios models is difficult.
  19. Aerosmith
    self employed
    2,987Coins
    3DOF, AC motor
    Yes, that's important. For Sven's rig we solved it that way: All 6 servo controllers are powered with a big contactor. Mains voltage is switched with NO contacts and NC contacts discharge the DC bus to power resistors. The ready signals of the controllers go to the motion controller. If one of the servos quits all others are also switched off. The discharge resistor acts as brake so while the rig sinks down the motors act as generators. This limits the speed and the rig drops in a controlled way instead of free falling.
    With rotary actuators you have the advantage that there's no hard stop at the bottom but the arms go to the dead point smoothly. With the rig on top on the platform theres also no collision risk as opposed to the "bathtub configuration" most others use where the foot pedal room is between the front actuators.
    My dual seat rig will also be very heavy and I fear a brake resistor won't be sufficient to shut down safely. I've bought small pneumatic cylinders that can press a rubber pad onto the timing belt pulleys to stop the rig from falling if one or more servos cut out. That's important for me because I have collision risk at extreme positions. Unfortunatelly, I've bought the servos too early and without built-in brakes. I think it won't be neccessary for your rig.
    That's a nice one with full building instructions. But so much work. I would have done it with PCBs instead of manual wiring. I think I have to postpone that until I'm retired.
  20. GettinBetter
    CAD Engineer
    Kent, UK
    746Coins
    Ah, ok. My servo drives are also powered through a contactor. I just need an output that I can use from the each of the servos (which will need to be latched, as I don't want power coming back on when the signal dissappears from the servo), which I haven't looked at yet.
    I do have hard stops at the bottom, as the arms would hit the floor, also I wanted it to sit level when not powered up. When the downward force starts to go around the lower arc, the translation to a horizontal component naturally slows the movement down, and I could always add some rubber pads to the stops if needed.
    LOL, yeah, me too. I should have defined the project parameters first.
    I only decided on a two seater after surveying the real helo, by which time I had already bought the motors and gearboxes. Still, its a hobby, so it doesn't matter, it's all part of the experience.
