Question 6DOF project
Discussion in 'DIY Motion Simulator Projects' started by Arlouze, Apr 15, 2021.
Tags:
  1. Arlouze
    Arlouze New Member
    64Coins
    Joyrider, Motion platform, 6DOF
    Hey guys,
    So, I started my 6DOF project and I thought it could be useful to create a thread about it. I want to avoid costly mistakes hehe. If you see anything wrong or suspect, tell it please !
    I plan to get : AMC AASD15A - RGB V1.4 as a controller
    80ST-M02430 as actuators
    AASD15A as drivers
    Thrust Master T-16000M as joystick
    I don’t know if reducers are useful or not in this case, or should I go for linear actuator ?
    --> I think I will just go for rotating actuator without reducers
    Are RFI online filters mandatory ?
    If you could give me advice about the electronic part, I would appreciate. Like the power supplier and stuff like that (a little diagram is not refusal). I saw some people uses switches, but I don’t think it’s useful in my case.
    Btw, I will use Mover and mainly control the whole platform directly with the joystick.
    Thanks per advance !
  2. Thanos
    Electronics Engineer
    United States
    2,830Coins
    You mean Line Filter to isolate the servo drives power from the mains...
    www.amazon.com/dp/B073MCGBP5/ref=cm_sw_r_cp_awdb_imm_YRHJD25DC1ZRTZ4M8MKV?_encoding=UTF8&psc=1
    See how this line filter is connected in this example:
    And some EMI and RFI measurements after:
  3. SeatTime
    28,320Coins
    You will need a gearbox/ballscrew attached to the servo motors, refer to the many examples detailed in the Project threads. AC servos normally can run directly from your house power - separate power supply not required.
