  1. Pierre Lalancette
    3D teacher
    Quebec, Canada
    7,683Coins
    3DOF, DC motor, Arduino, 6DOF
    I have similar concern about our three cats running around in the house. They are quite curious.
    I really like the way they covered all the mechanics in this simulator. It could give you some ideas.
    6dof CKAS for VR
  2. Doc Voliday
    Doc Voliday New Member
    South Carolina, US
    148Coins
    Signed up just to say how awesome this build is. I read through all 45 pages. I'll be taking a lot of advice from you and others on this board when I begin my project.
  3. SPHPilot
    SPHPilot Member
    324Coins
    What is the sound/noise level difference between your geared motors in the old setup and the new actuators you have in the new setup? Which is louder/makes more noise?
    I have a sleeping baby at home.
  4. SilentChill
    20,402Coins
    The gearboxes were silent pretty much but the actuators are quite a lot noisier but not really loud. Wearing the Oculus headphones I can not hear them and with my sim being in the basement I can make as much noise as I want :D
  5. djboss001
    djboss001 Member
    Test engineer
    - 34Coins
    Impressive work and installation! The result and the sensations must be excellent! Good job ! ;)
    Maybe the electrical equipment will deserve a dedicated cabinet?
  6. nicolasp
    nicolasp New Member
    são paulo, brazil
    23Coins
    [QUOTE = "Mmcool, post: 125100, member: 17740"] Ele está usando 2 arduino com o código 3dof se não estiver errado. [/ QUOTE]
    Eu acho que são 3 arduinos com 2dof código
  7. Stephen Robotham
    Stephen Robotham Active Member
    jamaica
    140Coins
    What size are the flexible shaft couplers, I need to order some but I don't know what size fits the hall sensor because I haven't gotten them yet. I am using the same time that you are.
    145,160Coins
    +10,780 / 52 / -2
  9. JAD
    JAD Active Member
    Australia
    1,446Coins
    Hi @SilentChill,
    I will soon be needing to make a choice on motor driver for my current build.
    I note your experience back in 2016 where you struggled with the Sabertooth 2x32 and you upgraded to 2x60 for your 270W 12V motors.
    After spending more than a year on your rig with the 2x60's, do you still believe the original issue you had with the 2x32 still stands? or did you subsequently find some other reason that they didnt work for you.
    By the specs of the 2x32, I would have thought it should be sufficient for your motors.
    Im checking with you on this before I purchase. I have 450W 24V motors in my build. By the specs, I would have thought the 2x32 should be OK. But not based on your experience.
    If I have to to go with 2x60's , so be it but at around AUD$300 in Australia , and I dont want to overdo it for nothing.
  10. Phil Barnes
    Phil Barnes New Member
    - 104Coins
    Wow! Awesome post - managed to drink 4 cans of Guinness whilst I read through the first 44 pages!
    Got a little excited, as I was to proffer myself for a fat bastard test for your rig - and then read you had someone who was 18 stone on it, so that was that!
    I remember reading you kept the railways running - as do I ;)
    So, I would dearly love to do this - I adore Dirt Rally and have a OSW and wind mod already - but I am upstairs in thee spare room and I know I pissed of the neighbour with my shakers and got rid as a result.....
    ......now my mind is thinking, "instead of buying a bike...." with the proceeds of the future sale of my TVR, I am thinking something very VERY different!!!!
    Thanks for the post and inspiration - awesome stuff! (and keep the updates coming mate!)
    Regards
    Phil
  11. llluis
    Quebec
    1,630Coins
    It's been a while since I read all this thread, but I believe @SilentChill had MotoMonsters before and upgraded to Sabertooths 2x60. I don't remember he having any issues with 2x32.
  12. JAD
    JAD Active Member
    Australia
    1,446Coins
    There was a brief period around Nov and Dec 16 (from pg 31) where he tried the 2x32's
    At pg 34 is when @SilentChill gave up on them and switched to 2x60's
    The more I think about it, I will likely go for the 2x60's anyway to keep plenty of headroom for now and the future.
    Im looking for reviews on these, https://www.cytron.io/p-mdds60
    Struggling to find anything on them. Only a little cheaper at A$235, probably not worth the saving compared to proven Sabertooth 2x60's
  13. bruce stephen
    general contractor
    michigan
    9,110Coins
    You can also add the kangaroo to the sabertooths and use optical encoders.
  14. llluis
    Quebec
    1,630Coins
    Problem is the battery.
  15. JAD
    JAD Active Member
    Australia
    1,446Coins
    All very good points. Thanks
  16. FoxONe42
    FoxONe42 6DOF newbie
    Flight simulator engineer
    Nantes France
    100Coins
    Arduino, 6DOF
    Amazing project. I haven't gone through the 45 pages yet but will do in the near future to find out interresting info I am sure.
    I just built a scale model of a 6DOF and I am working with SKetchup physics to have the same render as yours. Did you manage to make it work properly all the way ? I mean, mine acts weird when the servo angles gets higher (not that high though, somewhere around 30 degrees approx. I would say).
    Anyway, I'll try to post a video soon.
  17. Flymen
    Montreal, Canada
    2,416Coins
    DC motor, 6DOF
    Nice job ! thanks for the pics!!
    Q- why you put a part of wood to attach your motor ?vibration!!!
    Q- You used 1605 x( 600 or 500 mm ) ?
  18. Bami Salami
    Bami Salami New Member
    161Coins
    Very nice, will start with a 2DOF first
  19. SilentChill
    20,402Coins
    Late reply :)
    I used wood as its all I had at the time.
    I used 1605 500mm
  20. Benji85
    Benji85 Member Gold Contributor
    845Coins
    Awesome rig dude, is it still your main / in use one?
