Showroom 6DOF motion platform (P3D)
Discussion in 'DIY Motion Simulator Projects' started by Victor Urnes, Jul 12, 2019.
  1. Victor Urnes
    Victor Urnes New Member
    113Coins
    Motion platform, 6DOF
    Hello!
    We are building a 6DOF platform for P3D.
    The actuator we are using have the following spec:
    10kN.
    500 mm/s
    1000mm or 1200mm stroke (We have not decided yet, we are waiting for offer from supplier).
    The weight of the plane is about 700kg.
    Do you have some recommendation for the platform geometrirally?
    And which motion controller we should use?
    Also open for other tips regarding the planning and building.
    Victor
  2. Victor Urnes
    113Coins
    I aslo have one question too,
    What happends if one actuator fails? It could be loose wires or component error.
    That's pretty much forces involved into this. How could we prevent that?
    154,400Coins
    +11,181 / 57 / -2
    I suggest you go with the AMC controller by @Thanos, have a good read through its capabilities and functions and then post any specific questions: https://www.xsimulator.net/community/faq/amc1280usb-motion-simulator-controller.336/
    It would be helpful if you be more specific about what you are actually planning, it sounds like you intend using an actual cockpit and if so what are the dimensions. Even a hand drawn concept with rough dimensions would be informative for members who could then give some advice.
  4. Victor Urnes
    113Coins
    Okey. We are using a Piper Aztec 230. it is about 120cm wide. 250cm long. The cylindral projector wall has a radius of 1.7m. As said, total weight is 600-700 kilograms. The projector will sit on the top of the plane.
    Thanks.
    154,400Coins
    +11,181 / 57 / -2
    Is the user(s) + peripherals weight in addition to the 600-700 kilograms?
  6. Thanos
    Electronics Engineer
    United States
    2,917Coins
    Certainly you will need at least 1.5kw servomotors with 250mm/s actuators for such load. 300mm stroke maybe, 400mm stroke actuators better for larger diameter platform to allow stability without having to anchor the platform to the floor.
  7. SeatTime
    That's no toy :). The inertia in throwing 700Kg around would be massive. Recommend the foundations and most of the other parts be properly engineered. Hate to see someone getting hurt. As you are in the United States, you could lose your 'house' when they sued.
  8. Thanos
    United States
    2,917Coins
    This kind of full cockpit sim is not for "home" use. A special building or even a hangar is suited for these kind of simulators. Most of them have extra wide beams to extend the floor contact of the bottom triangle. But yes, if they plan to have the simulator sway or surge too much close to the edges of structural balance, anchoring to the floor is always desired, especially if the mass on top of the platform is placed high...
  9. SeatTime
    Just wanted to be sure he did anchored it to the floor .... It's also surprising what people put into their homes for personal use. Here's one of many I remember seeing over the years.
  10. Victor Urnes
    113Coins
    6-700 kilo is included users :) Yes Thanos, we have ordered 3kW motors and 1000mm stroke actuators. We buyed it from DGReletriccylinders. We are well engineering all the parts, so it should be safe. We will also force test the platform before mounting the plane on it. And yes, we will anchor it to the floor.
    I will not have it in my home. It will be placed in an old shipyard, or we will build a building for the simulator. We have not decided yet.
    Thanks for tips!
