6dof Motion platfor for VR flight sims
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by norsk22771, May 1, 2016.
  1. norsk22771
    norsk22771 New Member
    Norway
    190Coins
    Hello. Motion platforms have captured my interests and im doing a bit of resarch but i need help on a few questions because i am going to run either oculus rift or the HTC Vive i have now on the motion platform along with my Hotas.
    Soo to the questions:
    I am a littlebit unsure of what motion platform feels best for flight simulators, is it joyrider, 6 dof models or this one?
    i was thinking about making the motion platform of metal or wood, i have both experience in welding and littlebit wood working. My current budget for the motion platform is 3500-4000 Dollars.
    Another question, do the simtools work with 3DS MAX modelling program?
    150,578Coins
    +11,017 / 55 / -2
  3. Mic_n
    Mic_n New Member
    Sydney
    431Coins
    Dredging up an old thread here, I know, but as to materials...
    There are designs around using both. If you can weld, box steel is probably your best bet. Strong and light enough. Using timber generally winds up heavier for the same strength, plus it's not as consistent.
    I've actually been pondering recently the possibility of a composite structure.. Polypropylene hexagonal cored sheets can be had for cheap, and are amazingly strong and light at the same time. Skin it with fibreglass/basalt/carbon depending on budget, and you'd wind up with a very strong and stiff structure that is also lightweight.
    Inspiration for that style of construction comes from comes from the guys that made this EV nicknamed 'trev'
    http://www.autospeed.com/cms/article.html?&title=Building-an-Ultra-LightWeight-Car-Part-1&A=112925
    http://www.autospeed.com/cms/article.html?&title=Building-an-Ultra-LightWeight-Car-Part-2&A=112926
    That one's a different material, but the same concept. The same team have more recently done https://africansolartaxi.com/category/construction/ which is the sort of material & techniques I'm referring to.
